2.4 Slave cylinder - Transmission Forum
2.4 Slave cylinder
Wednesday, March 14, 2012 4:42 AM
Hey i was just wondering how many people have replaced a clutch slave cylinder inside the transmission. How tough is replacing it?? and does this sound like a slave cylinder problem when my has sat for a day and has fully cooled off i can shift smoothly but the more i shift and warmer it gets it will grind gears when shifting but when its sat for like lets say a day and fully cooled off i can shift into any gear no problem does that sound like the slave cylinder letting air into the clutch system?
Re: 2.4 Slave cylinder
Wednesday, March 14, 2012 9:19 AM
Try bleeding the clutch first. Flush it all out with new fluid. Check your transmission fluid level too.
And if it ends up being the slave cylinder, yo have to pull the transmission out to replace, so if it were me I would replace the entire clutch setup while it is apart.
Wednesday, March 14, 2012 1:39 PM
i bled it twice already and each time air came out :/ how do i flush out the old fluid?
Wednesday, March 14, 2012 2:59 PM
Bleed it with another person helping as if you were doing brakes. Or pressure bleeding it would be the best way. Check your fluid reservior line and hydraulic line from the master to slave cylinder. Sometimes the O-rings can deteriorate and allow air to enter as well.
Wednesday, March 14, 2012 3:44 PM
i did my buddy sam opened and closed the bleeder valve air came out i pumped it ten times before he opened the valve and when he shut it the pedal wouldnt return up. we bleed it once more no air came out just fluid and the pedal still wouldnt return up.
Wednesday, March 14, 2012 3:48 PM
The pedal won't return on a clutch system because it's not designed to. you have to pull it back up manually.
Wednesday, March 14, 2012 3:54 PM
oh ok got yah. so are slave cylinders on z24's known for going bad?
Wednesday, March 14, 2012 7:02 PM
It's fairly common on our cars. I'd say more so with the Isuzu transmission Vs. the Getrag. Engine doesn't seem to make a difference either.
Wednesday, March 14, 2012 9:26 PM
so does the 99 z24 have a isuzu transmission?
Thursday, March 15, 2012 9:17 AM
Yes. All 95-99 J-Body cars had the Isuzu transmission. 2000+ had the Getrag.
Thursday, March 15, 2012 1:52 PM
Sounds more to me like the transmission is low on fluid or needs the fluid changed.
Check the transmission dipstick.
-Chris-
-Sweetness-
-Turbocharged-
Friday, March 16, 2012 12:49 PM
its a 5 speed it doesnt have a dip stick. and on a scale of 1-10 how tough is taking out the isuzu tranny?
Friday, March 16, 2012 1:23 PM
Earl McNulty wrote:its a 5 speed it doesnt have a dip stick. and on a scale of 1-10 how tough is taking out the isuzu tranny?
Yes it does. Look again.
Your problem does not sound throwout bearing related as you aren't complaining about the pedal or its feel. The transmission is grinding when shifting into gear and the fluid is warm.
So step #1 is to check your fluid and possibly change it. I have fixed this exact issue 4 times by either adding fluid or changing out old fluid.
Or you could just pull the trans and change the throwout bearing if you want... 6 or so hours vs 20 mins sounds like a better idea.
-Chris-
-Sweetness-
-Turbocharged-
Friday, March 16, 2012 8:35 PM
wheres the dipstick located?
Saturday, March 17, 2012 7:32 PM
ok verdict it turns out the fluid was low like where it says add it was between the A and the D filled it up and it helped it out a little still grinds but not as hard imma change the fluid and see it that solves it. Major thanks to sweetnessGT your the man
Wednesday, March 21, 2012 8:24 AM
Wednesday, March 21, 2012 7:06 PM
so new verdict i changed the fluid twice and my car doesnt grind AT ALL ANYMORE! woo hoo!
