anyone know what exactly i will need to do to swap my 3 speed auto out to a 5 speeed manual on my 97 sunfire? already got the tranny from the same year car, along with the shifter, and the clutch pedal assembly. what elsedo i need and what kind of modification am i gonna need to do? thank you in advance if you can help out.-matt
Did I mention I drive a 2000 Lumina now?-----wigm-tuners.org member
master/slave cylinder ,flywheel, clutch, axles,mounts to weld to car and ecm flashed to manual
mikieb510 wrote:master/slave cylinder ,flywheel, clutch, axles,mounts to weld to car and ecm flashed to manual
Pretty much. The ECU flash part is not as importnat. The car will run and drive off the auto ECU, but will have a Check engine light because no auto tranny being seen. I would also recommend getting a manual engine bay harness and swapping it out. If not then you will have to cut and splice some wires to use the auto harness.
we'll if you get the manual wiring harness then would it work if you just get the manual ecu to make it even more simpler ????
josh p wrote:we'll if you get the manual wiring harness then would it work if you just get the manual ecu to make it even more simpler ????
Of course. Get the harness and ECU would work best.
i can get the computer flashed at work but if i use the auto harness how many wires do i have to splice?
i have another guy @ work telling me to swap to a 3800 SC and the 5 speed from the 2.4 will bolt up to it. is this true? if i can make that work, i am interested in doing it but i wouldnt iagine it bolting right up.
will the 2.4 trans work with ethier, or do i have to stick with auto, and use a 4t60-E?
its not as easy as everyone thinks
ive decided to do a 2.4/5speed swap now. got my donor car from a guy at work pretty cheap. i will need a 1.5 inch hole saw for the clutch master, correct?
