I recently installed a B&M short throw shifter. Now I have a hard time up shifting into 3 and down shifting into 4. Is there some kind of adjustment that I am not aware of?
2nd Place is the first loser
define hard....cause thge b&m is supposed to make it shift harder
As in, it wont go unless I double cluch or the gears just grind
I see you also posted on that other thread about grinding third- did you eliminate all those other things (synchros, shift forks,etc.) as the source of the prob. already?
Thats just it. I'll be honest here. I don't now a whole lot about tranys. I just got done turboing my car and want to drag race it so i put the shifter on. But I really dont know even where to start on this issue. i am thinking about just putting the shifter back to stock because I think I may have hurt something internal and want to start eliminating what could be wrong with it.
Cable clips misalgned when you put the B&M one in?
I followed the direction that came with the B&M. I thought I did everything right. By cable clips you mean where the shifter cables attach to the actual shifter? If so how would they have gotten misaligned?
there should be adjusters on the shift cables, assuming you adjusted these, its not in the shifter unless you totally @!#$ somthing up.
This really bums me out. I am usually really good with car stuff. But man i must suck w/ tranys. Ok when I hooked up the cables I didnt adjust anything. i just popped off the cables tore the factory shifter out swapped the parts around, installed the B&M and snapped the cables back on. Where do I need to adjust? Is it at the trany or inside the car at the shifter?
Thanks for all the help guys. I feel like such a dumb a55. I just want to get my car working right so I can go drag racing.
wow sorry about my post, i though it said b&m shifplus. for the autos...my bad..lol
The end of the cables are ribbed so the clips have soemthing to grab.
Did you mark the cable before you removed the shifter? I think Wild Weazer's how to stressed that part so you can get the clips back in where they belong.
With the car off, does shifting into the other gears fell just as hard, or do they slide right in?
No I didnt mark anything I dont recall the directions saying to mark anything.
Please keep in mind this is a 98z . It has the isuzu trany (I was told there is no adjustment to these cables)?
Oh, your right I was thinking 00+ INSTALL.
