Transmission slipping on 99 Z24!!! - Transmission Forum
Wednesday, August 03, 2005 2:02 PM
what can I do maitenance or anything to prevent slippage? Its an auto with 77k miles most likely not maintained at all. will changing the trans oil help any on the slipping? thanx in advance,
luis
Re: Transmission slipping on 99 Z24!!!
Wednesday, August 03, 2005 2:37 PM
changing the fluid is prolly the best thing you can do apart from new clutches or a shift improver
Wednesday, September 21, 2005 10:34 AM
MINE IS TOO. i have 146,000 miles on a 1998 z24 auto 4 speed. I have modified the airbox and bored out my throttle body. It shifts at redline instead of right before where it used to shift.
If I change my tranny oil and filter, will that help? I dont know when it was last changed and there is no dipstick to check it. Any help guys?
Wednesday, September 21, 2005 10:47 AM
from what i learned, changing the trans fluid every 50,000miles is ideal, if you havent changed the fluid since u got it, being over 50,000+ then a trans flush and new synthetic fluid is recommended along with what El Diablo said, get a shift improver like B&M Shift+ for under 50 bucks or the plug-n-play autotrans interceptor for like 130. hope that helps. also read the sticky faqs in the tranny forum, that'll help in deciding on what fluid to use and what not to use.
*Devil Z*
Wednesday, September 21, 2005 10:52 AM
ok, thanks. The last time my tranny sliped in my old 99 3speed cavalier with the l4 engine i just replaced fluid and it stopped. I hope that this will help. I just hope my tranny isnt bad. AND WHY THE HELL ISNT THERE A DIPSTICK???????
Wednesday, September 21, 2005 10:53 AM
by the way there are no sticky faqs in the transmission forum.
Wednesday, September 21, 2005 4:56 PM
no, thats true, but using the search function sometimes is a great asset. im trying to use it as much as possible rather than ask in the topic area. why? will in most cases the question u have was possibly asked already, so it saves everyone else time and yours waiting for a response. just my .02 cents
*Devil Z*
Sunday, September 25, 2005 9:38 PM
not having a dipstick is one of GM's "bright" ideas. its suppose to be a sealed tranny and should never need service. well thats not going to happen.
