CavalieRX wrote:Errr... Stop teasing us and tell us a price the a kit with the port fueler!!!!
Lee wrote:How much for that Inline fuel pump bill... I need one... I have a 250 Bhp 2200 on a stock pump....... I need an inline... Let me know
SunCavi_L61T3/T04E wrote:One more time Bill, good numbers.
Now, to ask you a couple of questions, and people can think I am flaming or whatever, but I know I am not and so will you.
You said that you put down close to 350 with the 16G on 23-25psi, roughly or do I have my numbers messed up right off the bat?
Now you switch over to a 20G which considerably flows more and you have to crank it up to 28-30 psi to squeeze 50 more hp?
If the amount of flow that 20G does on 18-19 psi is the same as 16G is on 23-25 psi, you should be able to get that 50 hp from just keeping the boost the same and getting those extra 50 from cfm increase.
Now I know that even if you would TRY to push the 16G to 2Bar, it would peak out and drop off right arouns 1.6 or so, since those are the more common measurements when it comes to my DSM boys.
Another thing is about efficiency.
Last time I got the compressor maps for a 14B small/big 16G, 20G, and 25G, on a 4G63 DOHC motor they all lose efficiency at right around 1.6 Bar MAX!
2 Bar would be an inch off the top of the compressor map if you know what I mean.lol
Cfm/air flow, is uncomperable in those Turbos, but they all lose efficiency at pretty much the same point, including my T3/T04E, only Turbos that can carry past 25 psi would be Ball bearing or really big ones such as .82, .96, A/R and some gigant compressors.
So how is your Turbo efficient at 28-30psi? and why did you have to crank it up so much only not to get so much.
I am not dogging the set up by no means, and you guys have surpassed me and my set up by far, so I have no room to dis here.
For everyone that might think I am doing that, I AM NOT, just asking a couple of simple questions.
Thanks, for my future info.
Rodimus Prime wrote:not a hint of detonation, stock computer just crying about 'misfires', LOL! (it isn't misfiring...its just working hard to fire, and thats just fine).
You mean the pesky 0300 code? I get those all the time and cant get them to go away
Bill Hahn Jr. wrote:
You can rest assured, I'd love nothing more than to strap the DFI back on, put on a killer cylinder head, a freeking HUGE turbo and downpipe, an ignition that would light up Pittsburgh,a 3" t/body, take off the air filter, maybe a shot of juice, and just get NASTY. But it wouldn't prove what I am out to prove, which is that a well-conceived set of parts can be amazingly broad in its power capability, and still be TRULY streetable, emissions-legal, and affordable.
SunCavi_L61T3/T04E wrote:So how does feel making your peak hp at damn near red line, I know I make mine at 6400 RPM and I shift at 6300-6400, it sucks for the next gear.
Good luck with your set up and VERY GOOD JOB.
I will be with YOU next year.
