how much power do you think that the gm supercharger can put out with mods and does anyone know if you can intercool that supercharger
ive got 1 of the few 2.4 s/c's that it would be possible to intercool
some guys have gotten over 200 whp with the s/c and a full list of mods
you wouldnt happen to have the list of mods they have
i want like 230 or 240 horse might hit it with a shot of juice
header , 2 1/2" exhaust , 62mm tb , ported head , 2.5 or 2.6 pulley
alky injection , or a 35 shot dry , should get it close to that range at the wheels
stage 2 or 3 clutch , and lsd would help out alot at getting that to the wheels also
the 2.7" pulley and i/e/tb should put you over 200whp.... forget a 35 shot. The only reason Im running so "low" powerwise is because of the fact that Im actually running the 2.5" pulley and the blower is actually losing power due to heat. With alky injection I should be in the 220+ whp range
i have a pacesetter 4 to 1 header with full 2.25 pacesetter exhaust with no cat aem air intake b&m shift rsm crank pulley 100 shot of nitrious nos wet kit i have no clue wut i got for power with that cause i havent driven the car in 4 months
well your crank pulley will have to go back to the stock size pulley for the s/c
the reason i say a 35 dry shot is to help cool the s/c , or to use the akly injection
also the closer the intake is to outside air the better for the s/c
y would my crank pulley have to go back to stock the under drive pulley will make it pull more boost with the stock blower pulley then if i get the 2.5 or 2.6 pulley it will pull more boost and does it have to be a dry kit or can you use a wet kit cause i have a wet kit in already
you need a larger than stock size crank pulley to up the boost
the small pulley would make less boost
and it has to be dry shot the fuel will hurt the blower
all you need to do is remove the fuel stuff from it and cap the 1 end of the nozzle for the fuel
so i need a bigger than stock crank pulley and a dry nitrious kit
[quote=97cavie24ls(JDM cav sedan)]ive got 1 of the few 2.4 s/c's that it would be possible to intercool
??one a the few you can intercool? How is it different then the ones made for by gm for 2k+ jbodys??
explain
1995 Cavalier W/2k1 Engine
if i explained id have to kill you after i told you , LOL
ill have pics up this weekend
I just wanted to add to this. The RSM crank pulley is stock size just a hell of a lot lighter. I think 8 oz to be exact.
The crank pulley size is irrelevant if you have the RSM pulley. so........ "97cavi24" is correct. Get the 2.7" pulley and a larger crank. or leave your stock sized RSM lightened pulley and just get the 2.7" S/C pulley. you should notice a difference with that stock sized lightened pulley from RSM. I bought it and a 62mm TB and I cut 3/10ths on average off my 1/4 times. 3/10ths for roughly $300.00 CDN is amazing.
JDM Civic Hatch
most rsm crank pullies were smaller than stock , the stock size was optional and if i remember correctly they are fairly new
chris laflower wrote:so i need a bigger than stock crank pulley and a dry nitrious kit
lol back to middle school
thh smaller crank pulley(ur under drive) will spin all assecoriees slower.....including a supercharger........ best bet is get the rsm lightened crank pulley and the new lightened altenator pulley they have........ both are stock size but lighter than stock
GM charger, RK 4-1 header, 2.5 custam bent exhaust, dynomax superturbo muffler, pulley boys 2.6 quick change pulley, and a bage of ice on the blower it made 238 FWHP.
( blower was still hot as hell.)
chris
'02 Z-24 Supercharged
TaetschZ24 wrote:GM charger, RK 4-1 header, 2.5 custam bent exhaust, dynomax superturbo muffler, pulley boys 2.6 quick change pulley, and a bage of ice on the blower it made 238 FWHP.
chris
you're putting out about 20 more horsepower than i figured. what is your boost at with that pulley? and is this on 92 octane?
it holds 6-7 lbs at any given RPM above 2500, it will climb to 7-8-9 depending on weather.
i need methonal spray bad.
chris
