OK, heres the deal i came across a deal for a Mitsu TD06 16G that has the turbine housing ceramic coated and the compressor housing polished, it has a T3 inlet flange so it will bolt to my header, and the guy said it good for around 365HP at 22 psi, my question is he says it bigger than a T3 -60 so would it be to big for my 2.2L build, it has a twin scroll turbine for faster spool up, just want some opinions, its brand new and its almost to good of a deal to pass up.
But i dont want to be at 5K befoe i make any boost, i plan to run 15psi and would like to have atleast 10 psi by 2500 -3000 RPMs and full boost at 3500 would be absolute ideal.
Mike
1992 GMC Sonoma GT #492. Oh, Its just a stock V6!
1999 Cavalier Coupe, daily driver, 2200/M5. Mods and pics are in my registry.
Sombody Needs to Make me a cool Sig, Because im Sig Challenged!
Support the site that supports your habit, Go Premium.
Im premium since January, but why doesnt it say that?????
good for X amount of horsepower at X amount of boost is a completely worthless statement. that could be so far off its silly. depends completely on other mods, platform, blah blah blah..
about the turbo get the specs and find a table of its efficiency then map your engine/rpms on it to see if its what you need.
Sounds like an evo turbo if i'm not mistaken. Doesn't Hahn sell the 16g with their kits? Can't see why it wouldn't work
yes Hahn does put Mitsu turbos on there kits and the one they out in the eco kit is a TD05 Super 16G, just not sure how much differance going from a TD05 to TD06 will make, proabaly a bigger turbine housing, the turbine h9ousing on the one im looking at has a 12 stamped on it, which is suppose to equate to a .89 ar on a garrettt turbo, but is a twin scroll entry into the turbine for much faster spool than a .89 ar garrett unit. I think im going to snatch it up, its a hell of a deal and i think it will work very well for my build.
Mike
