Adjustable Fuel Pressure Regulator for 2200? - Boost Forum
Sunday, February 13, 2005 8:41 PM
Is there such a thing? is there anything that can be modified to fit the 2200 fuel rail?
I have searched and searched and only found ones for the 2.4
'99 2200 LS CX1 Sport
Re: Adjustable Fuel Pressure Regulator for 2200?
Sunday, February 13, 2005 9:37 PM
im waiting for mine ( http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7952908436 ) to come in till then i dont know ill prolly have to take out all the shiznit inside the old fpr and just leave the housing intact then put this on
"dude, thats a girls car"
Monday, February 14, 2005 8:23 AM
nice, hey let me know how it fits
thanks
Monday, February 14, 2005 2:25 PM
do u use this with a fMu or instead of?
<img src="http://registry.gmenthusiast.com/images/h8hondaz/sig.jpg">
Monday, February 14, 2005 2:44 PM
depending on the FMU I think you can use that instead.
I know I have a BEGI/Cartech adj. FMU and you can set your baseline fuel pressure using that. You do not need an adj. FPR if you have an adj. FMU which allows you to set basline pressure. (at least that is my take on the matter)
<a href="http/www.cardomain.com/id/stevefire23">stevefire23</a>
Monday, February 14, 2005 2:50 PM
awww ok so i should be good with a CARTECH fmu? thanx for the quick response by the way.
Monday, February 14, 2005 4:58 PM
geez wish i wouldve know that b4 ordering oh well ill tell ya'll how it works out
Tuesday, February 15, 2005 6:00 PM
yeah it doesnt fit (as of now ) but im sure a little massaging willhelp her find a new home in my engine bay (im gonna have to devise a way to plug into the fuel rail im thinking tapping it ah 4 day weekend yes...
Tuesday, February 15, 2005 6:15 PM
Agent Omega custom fitted a Honda FPR onto his fuel rail! He also has a 2200 and I was curious as to how he managed it myself! He's on my friends list in my registry and I also have the mod in my future mod list! hehe
N2O + Bolt-ons = 220Hp/250Tq
Coming Soon:HpTunersPro, EagleConnectingRods, WiescoPistons, 13sec2200
Tuesday, August 22, 2006 4:26 PM
You can always use the fitting I make, adaptes the Fuel rail to a NPT pipe bung
You cant tap the rail its FAR to thin
And you cant weld to it because it sauldered together, if you do then the saulder will melt and ruin the rail.\\
No i cant spell
Tuesday, August 22, 2006 10:24 PM
i believe rksport makes one that directly bolts on but they want an arm and a leg. well maybe both legs.
Wednesday, August 23, 2006 10:24 AM
supposedly one from a lt-1 vette will work. direct bolt in. i've heard it many times from different people. i will be able to say for sure here soon, as i'm ordering an aeromotive p/n 13106 to try. good quality, and has a place to put a fuel pressure gauge, which works great for us 2200 guys since tapping the fuel rail isn't too easy.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=AEI%2D13106&N=700+0&autoview=sku
http://jbok.org
Wednesday, August 23, 2006 12:45 PM
...ok correction. a friend just let me know, that the correct one we need is actually a camaro/firebird lt1 afpr. it is just like the corvette one, but the mounting tab is on the opposite side, allowing us to mount it and the fuel lines be routed correctly. so it's aeromotive p/n: 13107. of course tho, any brand camaro afpr should work, including tpis and others.
http://jbok.org
Wednesday, August 23, 2006 3:14 PM
IIRC, the LT1 corvette Adj.FPR works for the pre 98 2.2's.
I bought one from someplace called Thunder Racing which was just a top hat conversion that had an adjusting screw. Used the bottom half of a stock GM FPR
Thursday, August 24, 2006 5:27 AM
Yeah, I ended up using this guy. It takes some "finessing" to fit properly, but works great, no leaks. (application: Honda Civic):
The aeromotive is a great unit as well, but I believe you would have to bypass the stock regulator. Didn't RK Sport make an ADJ FPR for our cars?
Sunday, August 27, 2006 11:50 AM
here is a holly http://www.holley.com/512-502.asp
DRIVE HARD OR DONT DRIVE AT ALL!!!
