I just installs a supercharger on my car and had the tune, it's idling really bad and stalling out when I'm not on the gas, what could be the problem? I need to install the correct spark plugs
"If one day the speed kills me, do not cry because I was smiling." - Paul Walker
The injectors that came with the kit, same as map sensor & gmpp tune was installed
Do you have an AFR gauge, that would certainly help to know what your AFR is doing? Is the By-pass valve connected properly? Any CEL codes?
i had a godspeed dyno garage out of state college install it, as i knew nothing about it. its definetely getting to much fuel
Need to see if the bypass is working properly.
I actually think i found my problem. It's still on the 1bar map sensor, i feel so dumb :\ , i got the kit used and never got a 2bar map sensor, does anyone know where i can get one?
