60lb Injectors? - Boost Forum
60lb Injectors?
Tuesday, July 17, 2012 10:19 PM
I have looked and looked but for some reason cannot find the 60lb injectors everyone is saying I need to use to go s/c on an ecotec, can someone post the link of where I can buy them It would be very much appreciated.
Re: 60lb Injectors?
Tuesday, July 17, 2012 10:56 PM
Go to cobaltss.net or redlineforums and pickup some stage 2 injectors that someone swapped out. They are 42 lb/hr and with a racetronix fuel pump I made the numbers in my sig with mid 30's for duty cycle. I ended up gettng mine for 75 shipped.
Re: 60lb Injectors?
Tuesday, July 17, 2012 11:10 PM
Hmm ok thanks, but if you made those numbers (which is what I am aiming for) with 42lb/hr then why do people run 60lb?
Re: 60lb Injectors?
Wednesday, July 18, 2012 12:22 AM
Most people go with 60's because they use the stock fuel pump, but with a racetronix pump and harness you can get more out of smaller injectors because of the increase in flow. Perfect example of this is in Tinkles TVS thread in P&M where oldskool went to retune the car with the same60's he was running on a stock pump and the mp62. With the eaton injector were dam near maxedout, then with the racetronix they had room to grow with the larger blower installed.
Edited 1 time(s). Last edited Wednesday, July 18, 2012 12:54 AM
Re: 60lb Injectors?
Wednesday, July 18, 2012 3:03 AM
JUCNBST is not wrong in what he is saying about the difference between stock fuel pump and racetronix pump. I think the harness might even be the difference maker.
Still I would go 60's. Mainly because of my experience/what pulley size your going to use/and safety.
My personal car(not a Eco), but supercharged and a smaller charger, I'm maxing out 42's. I'm also not likely at JUCNBST power either, but I do have the racetronix and harness upgrade.
I would always rather have more injector than need than not enough.
Re: 60lb Injectors?
Wednesday, July 18, 2012 8:27 AM
I have some rc 550cc (52.4lb) injectors for sale that I was running on my turbo eco. If your interested send me a pm.
If your interested in custom aluminum tilt wheel levers hit me up!
Re: 60lb Injectors?
Wednesday, July 18, 2012 9:35 AM
Alright understood, I'm planning on runnning a 3" pulley, but can I safely run a smaller pulley with stock internals? And for BOOSTEDECO im saving up money right now so for the moment no I'm going to start buying parts in december for the s/c because I am currently working on swapping an Eco into my car
Re: 60lb Injectors?
Wednesday, July 18, 2012 10:14 AM
Unless you have a very @!#$ty tune, you wont blow up an Eco with a M62.
Re: 60lb Injectors?
Wednesday, July 18, 2012 10:53 AM
so then whats the smallest i could run?
Re: 60lb Injectors?
Wednesday, July 18, 2012 12:45 PM
Tinkles(KGM) wrote:Unless you have a very @!#$ty tune, you wont blow up an Eco with a M62.
Exactly!!!
YOu can run a 2.8 on a stock Eco with M62. I would not run a 2.8 without either a very good h/e and dual pass setup (more than a ss/sc or cobra h/e), and or meth.
I have tuned a car without meth on a 2.8. He had the dual pass, and ZZP S3 h/e. IATs were nice in Fl summer weather, but we did not have watch timing a little.
Re: 60lb Injectors?
Wednesday, July 18, 2012 3:00 PM
keep in mind, these guys are not talking about running the GMPP reflash. you're going to need to be set up on HPT to make that work.
Re: 60lb Injectors?
Wednesday, July 18, 2012 4:02 PM
yeah someone already told me that the gm flash is garbage so im going to use hp tuners
Re: 60lb Injectors?
Wednesday, July 18, 2012 4:04 PM
I would still like someone to show me where I can get the 60lb injectors
Re: 60lb Injectors?
Wednesday, July 18, 2012 5:58 PM
Re: 60lb Injectors?
Wednesday, July 18, 2012 6:53 PM
thanks
