exhaust studs and turbo mani......... - Boost Forum
Thursday, August 25, 2011 8:42 AM
was looking into converting the exhaust studs to bolts to make a better connection to the turbo manifold....tried searching and only thing i found was people talking grade 8 or stainless steel bolts for turbo to turbo manifold
what is everyone using just the stock studs ? or are you converting
Re: exhaust studs and turbo mani.........
Thursday, August 25, 2011 8:43 AM
studs have higher clamping force than bolts do.
Hence Head Studs > Head bolts
Thursday, August 25, 2011 8:57 AM
I am using studs. Only way I can see using a bolt is how camron's is, tons of little bolts I would say all around it.
Thursday, August 25, 2011 9:38 AM
Im still using studs with lock washers and bolts. Never had a problem with exhaust leakage.
Thursday, August 25, 2011 11:04 AM
WHITECAVY wrote:Im still using studs with lock washers and bolts. Never had a problem with exhaust leakage.
which lock washers and bolts do you use?
Thursday, August 25, 2011 2:00 PM
Just some stainless steel ones I got from Lowes, nothin fancy.
