i was wondering wow all you boosted ppl are running all your vac lines? i was going to buy a vaccum manifold but i decided to make my own 4 port manifold to run the blow off,vents,boost gauge and fpr.... i was wondering if anyone else is using one? im just not sure how efficient thats going to be....since the stock eco manifold only has one vac port on it..
I had a bunch of T's for my vacuum lines up until a few months ago when I switched to a Blox vacuum manifold. It really helped clean up the clutter and I haven't had a problem with it at all.
I have my compressor housing to wastegate wit a boost controller t'd in. Then manifold to bov with boost gauge t'd in. All hidden under stuff so no mess
Ryan Thompson wrote:I have my compressor housing to wastegate wit a boost controller t'd in. Then manifold to bov with boost gauge t'd in. All hidden under stuff so no mess
Everything else is stock location
I have a couple tees off the back of my manifold, no problems.
Vacuum blocks work well. I use one and don't have any issues.
i made a vaccum manifold because i only have one vac port on the stock eco manifold.. ill run the boost controller off the compressor of cours the the fpr boost gauge blow off and air vents off the block...i just didnt know if it will read accurat boost presssure being teed off a vac block with 3 other things taking vaccum
