Tinkles wrote:If you can top these numbers.
And provide the runner to runner accuracy then i might be interested.
IamQwibby (Eco Meatcake) wrote:the problem with L61 heads is the coolant passages between the runners on the exhaust ports, which hahn and someone else found out about the hard way
ammfab wrote:. the car made 296 whp at 9.5 lbs on the stock engine so now that we are increasing its volumetric efficiency im hoping new numbers at 10lbs can be in the area of 350-360 whp, and thats just a wild guess on my behalf so if im off and u think it may differ by all means let me know.Let me start off by saying the head work looks pretty good! As for the quote above, Those numbers seem a little bogus. What are turbo specs? What dyno? Do you have a graph (with boost ref line tapped/recorded) to support this?
QWK LN2 (needs an @ss whoopin) wrote:ammfab wrote:. the car made 296 whp at 9.5 lbs on the stock engine so now that we are increasing its volumetric efficiency im hoping new numbers at 10lbs can be in the area of 350-360 whp, and thats just a wild guess on my behalf so if im off and u think it may differ by all means let me know.Let me start off by saying the head work looks pretty good! As for the quote above, Those numbers seem a little bogus. What are turbo specs? What dyno? Do you have a graph (with boost ref line tapped/recorded) to support this?
ammfab wrote:They seem a little inflated for that amount of boost on that turbo, especially on a stock engine. It just seems odd that there are a bunch of similar vehicles on here with same or similar setups, and some with different turbos that are more in their efficiency range at that boost level, and nobody else is close to putting those types of numbers down with that little of boost. If those are in fact what the dyno plotted, they have some serious issues with the loading parameters and weather station info...QWK LN2 (needs an @ss whoopin) wrote:ammfab wrote:. the car made 296 whp at 9.5 lbs on the stock engine so now that we are increasing its volumetric efficiency im hoping new numbers at 10lbs can be in the area of 350-360 whp, and thats just a wild guess on my behalf so if im off and u think it may differ by all means let me know.Let me start off by saying the head work looks pretty good! As for the quote above, Those numbers seem a little bogus. What are turbo specs? What dyno? Do you have a graph (with boost ref line tapped/recorded) to support this?
turbo was a 60 trim with a .63 hotside, dyno was a dyno jet 224 or 248 i dont remember which.............. and ive never got around to seeing the graphs, maybe aaron can chime in on this one cause its his car and hes the one that took it to get dynoed. that being said whats wrong with the numbers?
mike
QWK LN2 (needs an @ss whoopin) wrote:ammfab wrote:They seem a little inflated for that amount of boost on that turbo, especially on a stock engine. It just seems odd that there are a bunch of similar vehicles on here with same or similar setups, and some with different turbos that are more in their efficiency range at that boost level, and nobody else is close to putting those types of numbers down with that little of boost. If those are in fact what the dyno plotted, they have some serious issues with the loading parameters and weather station info...QWK LN2 (needs an @ss whoopin) wrote:ammfab wrote:. the car made 296 whp at 9.5 lbs on the stock engine so now that we are increasing its volumetric efficiency im hoping new numbers at 10lbs can be in the area of 350-360 whp, and thats just a wild guess on my behalf so if im off and u think it may differ by all means let me know.Let me start off by saying the head work looks pretty good! As for the quote above, Those numbers seem a little bogus. What are turbo specs? What dyno? Do you have a graph (with boost ref line tapped/recorded) to support this?
mike
BlueBoost (Itsjustacavalier) wrote:And I'm still going to call BULLSH!T until I see actual proof... I believe you made those numbers, but at a higher boost level than 9.5 psi...
Have you actually seem my turbo setup? It is a one off turbo setup so i assure you that nobody has the "same" setup... I'm sorry that you feel that way dude, but I haven't see anyone else running an equal length tubular turbo manifold, 44mm wastegate, and a massive intake manifold w/ velocity stacks on a stock engine... I assure you that those numbers are NOT inflated... I find it actually ironic because I was running rich on the dyno LMFAO... I would have easily thrown down over 315whp @ 9.5psi... and I didn't need the boost logged because I run a digital gauge in the car... I was more curious about the AFR's @6300-6400rpm... more or less diagnosing the fuel pressure problem... I can make it worse by saying it was off of a GM supercharger reflash and 91oct lol... it is what it is...
BlueBoost ItsJustaCavalier [F.A.S.T.]
(itsjustacavalier)
Last Update: Monday, May 17, 2010
Email: itsjustacavalier@yahoo.com
Private Message
Add to Friends
Profile Cars Forum
2003 Chevrolet Cavalier
About This Vehicle:
112mph 1/4mi trap speed on stock internals... Now has forged internals and a ported head... The car weighs in at 2400lbs (full tank of gas)
Body Style: Coupe
Color: Blue / Black
Engine: 2.2l Ecotec (L61)
Transmission: Manual
Interior: No Interior / Black
Purchase Date: n/a
Purchased From: n/a
Build Date: ongoing
Quarter Mile Timeslips:
10:00 PM - 01/Jan/09 - Speedworld AZ (13.410@111.8)
Manufacturer Options
Ls Sport Coupe
MODIFICATIONS
Engine:
-ENGINE-
Wiseco 8.9:1 86.5mm
Eagle rods
ARP Head and Main studs
AMMfab Head Port & Polish
AMMfab intake manifold
ZZP Valve Springs
Comp Cams (turbo)
Cometic MLS Head gasket .040"
RKSport UD Pulley
65mm Throttle Body
Custom Grounding Kit
Beryllium Copper Spark Plug Springs
Champion copper REC10YC4 spark plugs
Royal Purple 10w-30
-FUEL-
Aeromotive FPR
Walbro 255 fuel pump x 2 (in tank and external)
60lb Siemens injectors
-EXHAUST-
Custom 3" Mandrel bent exhaust system (Black)
Magnaflow 18x5 round muffler
Apexi N-1 Turbo Muffler (Black)
Open Dump 1 7/8"
-TURBO-
AMMfab Med Length Tubular Turbo Manifold (top mount)
AMMfab 2.5" Hot piping
AMMfab 3" Cold piping
AMMfab 3" stainless downpipe
AMMfab Intake w/ K&N Filter
AGP Zeta 3.0 turbocharger
TiAL 44mm wastegate (.25 bar Spring)
TiAL Q BOV
TurboXS Dual stage BC
800hp FMIC (4.5" thick)
-TRANSMISSION-
Stock F23
Stock Diff
Stock clutch
Ebay short shifter
-MOUNTS-
RKSport upper engine mount
RKSport lower engine mount
Prothane Trans mounts
Suspension/Wheels/Brakes:
-SUSPENSION-
Ksport Springs
Front and Rear strut tower braces
Control Arm Bushings
-WHEEL & TIRE-
17x9" Drifz wheels (black w/ chrome lip)
255/40/R17 Sumitomo Tires
ARP Camaro wheel studs
Forged Lug nuts
-BRAKES-
Drilled/Slotted Rotors
Hawk Performance pads
Interior:
Fully gutted
Removed A/C unit
Removed Dash
Removed Headliner
Removed ALL carpeting
Removed ALL interior panels
Removed Center Console
Removed Stereo head unit and speakers
Removed Front Crush Support
Removed Rear Crush Support
Removed jack and spare tire
Removed Rear speaker molding
Sheet Metal spare tire well
Tenzo-R Turismo steering wheel (black)
NRG Quick release hub v2.0 (black/cf)
NRG Carbon front racing seats (black)
Razo 340 shift knob (Black)
Custom LED lighting (white)
Autometer 5" tach
Custom blue LED shift light
AEM UEGO
AEM Tru-Boost
Exterior:
2-tone paint (blue body black top)
CF Hood (OEM)
Smoked tails
Rear Bowtie Removed
Bumpers cut out
FMIC painted black
black Moroso kill-switch at trunk key hole
Tint- double limo rear/ 15% front
Audio:
No Stereo
Miscellaneous:
HID's- 8000k headlights Hi/Lo
Short Shifter
Summit Battery Relocation
108 oct. Torco Race Fuel or Torco accelerator
Removed Cruise Control Unit
Dynoed 278whp on 7.5 psi w/ 91 oct.
Dynoed 296whp on 9.5 psi w/ 91 oct. 10.8:1 Afr
Future:
Lexan glass kit
Jeg's 8pt roll cage
spec stg III+ clutch
Big Stuff 3 stand alone
AEM Meth kit
Wilwood Brake conversions
koni yellows
eibach sway bars
ammfab wrote:well im back with the newest addition to blueboost's car. well actually lets get u guys up to date on things first . well the old head cracked in the combo chambers and was pushing coolant into the exhaust so the engine got pulled out and tore down. nows the chance to upgrade so we did. its getting a built bottom end, cams (and springs), head work, turbo, clutch, flywheel, lsd, new bearings etc. the car made 296 whp at 9.5 lbs on the stock engine so now that we are increasing its volumetric efficiency im hoping new numbers at 10lbs can be in the area of 350-360 whp, and thats just a wild guess on my behalf so if im off and u think it may differ by all means let me know.
so ive been porting heads for 6 years now mainly dealing with neons and dsm's but its time to open new doors and the ecotec is one of the ones chosen. anyways so he had an extra head (lost foam cast) so i said let me see it and ill work some magic. this head was not easy to port for a few reasons....... 1, my carbides were dull and this lost foam stuff is hard! 2, the intake ports are so damn long that its hard to be steady while getting all the way up in there but in the end the final product is amazing. now i dont have numbers yet but i will get them for sure. im guesstimating upwards of 300cfm on the intake side (that may be pushing it a little) and i hope to see at least 200cfm on the exhaust side. its at the machine shop right now getting the valve job and resurface before it goes to the flow bench. anyways im at work right now so in a few hours ill get home and throw a few pics up, ill take alot more once i get the machine work done. oh and this is getting +1 intake and exhaust valves in case anybody was wondering.
mike
blackbirdracing wrote:^^^ hell Vince I say that to everyone...
Everybody has more mods than me....
BlueBoost (Itsjustacavalier) wrote:I did "READ" the the whole post. Your Profile states its fully built, but that was last updated back on May 17th, so roughly 3 months ago. What the OP posted, it sounds like you are just now building or are finishing the build. The timelines just didn't match up. I'm not hating, I definitly dig the setup, I just don't believe those numbers on a stock engine with the specific turbo mentioned at the boost level and AFR... Its just not realistic. I have been doing this WAY too long and know better.... I do look forward to future higher numbers in its current form. Maybe one day we can line em up!ammfab wrote:well im back with the newest addition to blueboost's car. well actually lets get u guys up to date on things first . well the old head cracked in the combo chambers and was pushing coolant into the exhaust so the engine got pulled out and tore down. nows the chance to upgrade so we did. its getting a built bottom end, cams (and springs), head work, turbo, clutch, flywheel, lsd, new bearings etc. the car made 296 whp at 9.5 lbs on the stock engine so now that we are increasing its volumetric efficiency im hoping new numbers at 10lbs can be in the area of 350-360 whp, and thats just a wild guess on my behalf so if im off and u think it may differ by all means let me know.
mike
Now if you actually READ the post and not just focused on everything else you would understand my updated info on my car... there is a thread on the turbo setup on my car... just go read that dude...
