And found the limit of my Spec Stage3 Clutch. After this pull the power dropped to 380 then to 352 and the clutch was done for...
410 without correction w/correction...
415.6hp and 341tq (remember to add about 18% for DynoJet numbers = 490ish) that's up from 381.3 on the secret cams.
Cams are the ones Kris Bloom had custom made from Elgin Cams. I got them from Cory ( Zs Z ). HO spring swap. Cam specs are .404 lift @ .050 and 218* duration.
Suggestions for a new clutch? Narrowed down to ClutchMasters or Bully.
"The FACTS are always subject to CHANGE once the TRUTH is applied"
"In the entire history of man the only stupid questions are the ones that don't get asked"
Awsome numbers, glad the cams worked out for you.
Holy @!#$! Awesome Numbers Gary. Is that with the cam I sold you?
Very nice! And I say go Bully stg4
Amazing dude! congrats!
I think you will be happy with either of those two clutches.
Nice Gary! How much boost you running now?
P&P Tuning
420.5whp / 359.8wtq
Why did you only pull to 6800? It looks like that's where you're making peak power.
I have no signiture
bad ass numbers!!!!!!!
8 psi with m62 and IAT under 100
Still running 19lbs. boost to keep everything in comparison. 6850 is where I had the rev limiter set to,really not trying to push all the limits right now,just running more as a test mule for data....
E85 is the shiznitz...
damn gary your car just wants all your money.lol
R.I.P. Brian Klocke, you will never be forgotten
Bully has the best grip and engagement, albiet, that comes at a big cost of money ($930ish Canadian for my stage 4 6puck, straight from Bully) They will warranty ANYthing as long as you have proof that a new master/slave were installed, as well as a properly machined flywheel, at the time of the clutch install.
i can beat bully's pricing
and the warranty part is also very true, seeing it first hand right now
Shoot me a price on a stage 4 6 puck and I'll get a quote FX 700 with flywheel. I'm running a RKsport (fidanza) flywheel now so I can just replace the insert for the stage 4x6...
Shipping will be to 67060
Edited 2 time(s). Last edited Monday, May 31, 2010 7:27 AM
Please for the love of GAWD use a stock flywheel lol. I would hate to see your engine bay be destroyed from an exploding Fidanza. It's not worth the risk especially with how much time/money/hard work you've put in to your car!
wow gary, extremely impressive.
now, get a good clutch, turn up the boost and rev to 7500. LOL 500+ on a dyno dynamics would be INSANE.
180hp in 1989 or 145hp in 2002, you decide. >
Congrats Gary
Good stuff Gar. get that clutch issue resolved and wind her out a bit more. E85 is amazing!!!!
Awesome numbers! I'm running a 4 puck unsprung hub ACT on my car and it grips like a MOFO... engagement is harsh and it's not exactly a friendly in traffic car but i've gotten pretty used to it now and love it
President/Founder - 607 Motorsports
Some sweet numbers.
What cams and springs are in there now?
As far as the Fidanza Flywheel,It's been in there for 20k miles. Been through the Super Charger,the first,second and third Turbo setups,autocrossed,dragged and beat on pretty good. I think if it was going to shell it would have done it by now. If I remember right a lot of the trouble was people weren't putting flat washers between the bolt head and flywheel and digging into the aluminum real bad.
john317(AKA Gary the Old guy) wrote:Quote:
Yuck that happened to my LSJ's flywheel at one point. Makes it impossible to torque the bolts properly when it just keeps digging in.
