I'm lookin for the part # for ngk plugs 2 steps colder for an eco
z28guy(KGM BEOTCH)
Skunk posted them a month or so ago, i'll try to dig up the post
*Edit*
Found the post quicker on ecotecforums, but here it is:
NGK eco spark plug part numbers
*2nd Edit*
Cliffs:
NGK spark plug choices for the ecotec:
Iridium
LTR5IX-11: Stock replacement
LTR6IX-11: One step colder
LTR7IX-11: Two steps colder
Edited 2 time(s). Last edited Monday, October 19, 2009 10:52 AM
Tinkles
2003 Cavalier 1SV
Bagged and Blown
u da man thanx
z28guy(KGM BEOTCH)
Yes, it is a very rare day when i do that much searching for something i know is posted.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
ngk-6510
most damn part stores cant find the other number grrrr!
2.2 L Ecotec, P&P Head, Stage 3 Comp Cams, Supertech 76 lb Spring kit, Supertech Oversized Valves, Wiseco 8.9:1 CR Pistons, Eagle H-Beam Rods, Home-Built Turbo Kit T3/T4 57 Trim Intercooled, 78 lb/hr Racetronix Hi-Z injectors, Aeromotive FPR, Racetronix f body fuel pump,MEGASQUIRT MS3 + MS3X Finally street tuned on 21 lbs! Now if only I could get it to hook....
Anyone have the part number for non Iridiums?
Thanks tinkles
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
Non iridiums resitor types: from sparkplugs.com
Heat range 7 - BR7EFS - stock number 1094 - gap 0.027"
Heat range 8 - R5724-8 - stock number 7317 - gap 0.019"
these are 14mm thread, 17.55mm (0.691inch reach), 5/8" hex, tapered seat
These would work for my 98 sunfire. Verify reach or length. Always compare to your stock plug to make sure it's not too long.
