Just finshed my supercharger build. only one problem. i bought a gm reflashed pcm and it wont start my car. the engine just cranks over and dosnt fire also the theft light stays on when im trying to use this pcm.. but when i hook my stock pcm back up it runs like a champ. How do you reset the theft system so i can use the reflashed pcm that i bought,
iill post pics and add some moreinformation about the build tomorrow. its 4:53am and im exhausted. any suggestions on how to get around this theft system problem would be greatly appriciated.
CarDomain http://www.cardomain.com/id/TMald123
2000 to 2005 Cavalier / Sunfire
1. Turn ON the igniton, with the engine OFF.
2. Attempt to start the engine, then release the key to ON (vehicle will not start).
3. Observe the SECURITY telltale, it will be flashing. After approximately 10 minutes the telltale will turn OFF.
4. Turn OFF the ignition, and wait 5 seconds.
5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes. The vehicle is now ready to relearn the PASSlock Sensor Data Code and/or passwords, on the next ignition switch transition from OFF to CRANK.
IMPORTANT: The vehicle learns the PASSlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You MUST turn the ignition OFF before attempting to start the vehicle.
6. Start the engine. The vehicle has now learned the PASSlock Sensor Data Code and/or password.
mine was that hard, I just turned the key on to alt power for 10 minutes turned it off and boom strated right up
LE61T PTE6262 Powered
Does not sound like theft lock. Theft lock starts for 2 seconds then shuts off.
is that the same for 00+ i know some new GMs (SC flash might be this way)it doesn't even enable the injectors the 05+ equinox is this way it will crank and crank till the cows come home if that theft lights on its not gonna start
my 99 starts then dies 2 seconds later i think its a new GM thing
JBO since July 30, 2001
00+ will crank and crank and crank
follow the instructions and you will be fine
Apparently you need the BCM also from the car that was programmed for the s/c. The ECM and bcm need to match or have the VAT system disabled via HPTUNERs, but you cant modify the gmsc tuned ecm
(Tom) S/C Fire wrote:Apparently you need the BCM also from the car that was programmed for the s/c. The ECM and bcm need to match or have the VAT system disabled via HPTUNERs, but you cant modify the gmsc tuned ecm
No,I bought the computer from jbody04 and had it in my car with out the matching ecm.Tom do the relearn and it will fire right up.Also post some picture when you get a chance.
Andrew Manczak wrote:(Tom) S/C Fire wrote:Apparently you need the BCM also from the car that was programmed for the s/c. The ECM and bcm need to match or have the VAT system disabled via HPTUNERs, but you cant modify the gmsc tuned ecm
I guess I'll have to try that sometime, that way I can relearn anti-theft (don't know what good that is on a car with no alarm, lol)
alarm scares people away the anit theft prevents the car from moving if they tamper with things
Figured out why it wouldnt start. did the passlock relarn and it fired right up. So thanks for that tip.
Build information:
- RK sport lightweight Flywheel
- Spec 6 puck clutch
- New waterpump and timing kit
- M62 Supercharger setup. intake has endplate mod
- Intercooled
- Ram air intake
- Full 2.5" exhausr
- RK sport upper and lower mounts
Pics: in order from beginning to end
http://i10.photobucket.com/albums/a148/DToutlaw/P8120264.jpg
LS1?
Finished Product
Ill post viedos later, i have one more question thou. Im not quite sure it my bypass valve vacuum line are hooked up correctly i have the top one going to the nipple off the charger and i dont have the bottom one hooked up to anytinng. is that right? Im only making 6-7 pounds of boost with the intercooler dose that sound right too? id like to thanks everyone who helped and gave me information to complete this project especially airtonics who sold me the kit,
paint the blower to match ur cover and it'll looksick,...
Whitez wrote:00+ will crank and crank and crank
Every Ecotec swap we have done, car would start and shut off, after relearn would start and run. This was even on a 05 Ecotec.
We also found that some 2000+ we had to swap key switch as well, but some pre-00 we did not.
Nice build.
Good luck with the Flywheel though.
Those aluminum ones give me the creeps...
Legendary Bash Veteran
Should have stuck with teh pushrod motor you had in there.
looks sweet! add another one to the boosted list haha
Yes, you have the bypass valve hooked up right and im only making 10psi(i hit 11 once) on a 3.1" pulley with stock exhaust.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
cool
12.33 @ 111.67 mph [Oct 2009]
327.6 WHP 333.6 WTQ [10.1 AFR]
I was only making 8psi with intercooling mods so that sounds about right. won't be long before you will be swapping pulleys
you always want more..
evilmonkitar wrote:you always want more..
so true, i thought i would be fine with a 3.0 pulley @13psi, not enough, im dropping to a 2.9" looking for ~14.5psi...
