Does anyone use these for their oil line fittings?
Should I just use a regular wrench and be extra careful?
"You can only feed them semen for so long before their legs fall off."
I use them for AN fittings... should pick up a set, they're nice.
2001 Olds Alero (LD9)
636 whp / 543 ft-lb
@turboalero
So dang expensive tho. Stupid aluminum... Might just pick up a 4 and 10 from jegs then. Would get the adjustable but it's like $50-80 bones.
Hell I just use an 18mm socket and wrench lol
^yup...AN wrenches are nice but they are way over-rated in popularity
"Never argue with an idiot. They'll drag you down to their level, then beat you with experience!" -Anonymous
I just use standard wrench too.
I never really could understand the theory behind using the AN wrenches instead of standard.
If it's torqued correctly it really shouldn't matter.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
