Direct port alcohol/water injection? - Boost Forum
Monday, March 09, 2009 12:28 AM
Anybody here running direct port alcohol/water injection, and do you have any photos of your setup?
Re: Direct port alcohol/water injection?
Monday, March 09, 2009 12:36 AM
if you are talking about a supercharged setup, just get a blower spacer.
12.33 @ 111.67 mph [Oct 2009]
327.6 WHP 333.6 WTQ [10.1 AFR]
Monday, March 09, 2009 7:38 AM
why wouldn't you want the cooling mixture to pass through the supercharger and the intake manifold? that's where a lot of the heat is extracted
2001 Olds Alero (LD9)
636 whp / 543 ft-lb
@turboalero
Monday, March 09, 2009 9:52 AM
There is barely any room on the M62 intake manifold. I have look at it quite a bit trying to figure out how to run a direct port nitrous set-up and its a no go. There just isnt the room.
Trevor Mullins wrote:
kind of like a screwed up kids sing along
pete the anal monkey lived in my bum..............
best epiosode of barney ever lol
Monday, March 09, 2009 11:11 AM
theres no advantage in doing so, you want it after the throttle but as far away from the head as you can go
Monday, March 09, 2009 12:22 PM
^I agree, you gotta atomize or forget it.
6" is roughly the minimum distance from head entrance but that depends on many things, also with a 90 degree offset from flow direction. I got this number from the guys over at RSR.
Edited 2 time(s). Last edited Monday, March 09, 2009 12:24 PM
"Never argue with an idiot. They'll drag you down to their level, then beat you with experience!" -Anonymous
Monday, March 09, 2009 12:57 PM
Tinkles wrote:There is barely any room on the M62 intake manifold. I have look at it quite a bit trying to figure out how to run a direct port nitrous set-up and its a no go. There just isnt the room.
check out zz performance, they have a blower spacer. might be handy for n2o
Monday, March 09, 2009 1:58 PM
I saw that, but there might be clearance issues with that if i move on to a larger blower.
Monday, March 09, 2009 3:37 PM
Pish Posh there is not enought room!!! Seen it done.
Monday, March 09, 2009 5:16 PM
^lol
Monday, March 09, 2009 5:19 PM
Pics? I wanna see where the nozzles were placed.
Monday, March 09, 2009 5:44 PM
I don't have pics. Was not my car.
I plan to run direct port one day. I see no reason not to be able to.
Monday, March 09, 2009 8:20 PM
Are we talking about the same engine?
Tuesday, March 10, 2009 3:22 AM
I'm talking about a 2.4. Motor was never brought into this post.
Tuesday, March 10, 2009 7:22 AM
Ah, i was talking about the Eco with the M62. I dont care about the LD9s
