Its from a 89 turbo firebird GTA.. Since I dont have a reflash or anything we're gonna try to use this, but not sure if it will 'connect' to my wiring harness.. Anybody know for sure?
Ive attached a pic(or not)
or
Go to gmpartsdirect.com and type in 16040749
Thanks.
Edited 1 time(s). Last edited Thursday, March 22, 2007 6:43 PM
if it is 3 wire in, 0-5 volt output, then yes. You may have to alterter the wires if everything checks out voltage wise.
I have kinda been wondering that. I went to a 3 bar on the typhoon, and I have a spare 2 (stock)bar map. I have done NO research on it though. I just have a spare TD06 turbo , 2bar map, MBC, and boost gauge sitting around off the truck. One day, I may get to use them on something...
2004 Cavalier. Razzi. (Sold)
1998 Corvette. Some mods.
1992 Typhoon. Lots of mods.
1994 Civic VX 44MPG
Yeah they changed part numbers.. And I found out this wont connect up at all to our wiring harness. My buddy had and one of these sensors laying around, then tried to hook it up to my car(which is over his house) and it didn't connect...
Will my stock map sensor see boost at all?, I mean what are you guys using who don't have the reflash? Ill be using hptuners, but I dont know if I can do anything with that for the map.. Ill have to search around here and find out..
Thanks.
Get a MAP from a supercharged GTP at the salvage. It'll plug right in. I got mine for $10...
"The FACTS are always subject to CHANGE once the TRUTH is applied"
"In the entire history of man the only stupid questions are the ones that don't get asked"
Sweet, thanks Gary!!!
will this work with a 00 z24?
i'm thinkthe the 2.4 are all the same and i am saying yes to my own quest so someone correct me if i am wrong.
john317(AKA Gary the Old guy) wrote:Get a MAP from a supercharged GTP at the salvage. It'll plug right in. I got mine for $10...
That is a 2 bar, the one he is looking for is the 3 bar. Both share the same connector so both with work. Just make sure to tune for the sensor you are using. We ran the 3 bar on Andy's up to 21psi and it worked fine, just took a little longer to get driveability good as the resolution of the tables gets pretty bad the more you scale the tables.
Quoth the Raven 'Nevermore
raven@accesswave.ca
Raven Autosports
55 McQuade Lake Cres,
Halifax, Nova Scotia, Canada
(902) 850-3330
10.82@132
