Idles high after pcv hooked up - Boost Forum
Sunday, November 19, 2006 12:28 PM
OK i have a 2.4. Working at boosting it. I tapped the hole in the head and installed a npt barbed fitting. I the ran a vac line from the fitting to a small fuel filter and then to a check valve then to the intake mani. I have the hose that goes from the timing chain cover to the oil/air separator installed. I don't have the other hose that goes from the separator to before the turbo hooked up yet but i did cap it off for now. Every thing is clamped and seem to have any leaks. But the car idles high. IF i pinch off the vac line that goes to the oil/air sep. the car idle about 300 rpms. less. I also have a lot of black smoke coming out of the turbo (exhaust no hooked up) seems like car is running rich. any ideas?
2nd Place is the first loser
Re: Idles high after pcv hooked up
Tuesday, November 21, 2006 5:05 AM
is your map sensor plugger correctly??
http://cavalierdomination.monchar.com
