hi everyone,
just wondering if anyone could tell me where to get larger injectors from that will fit the 01 cav 2.4 I noticed the car has different injectors than the older 98 2.4s ive seen. looking for some 42lbers or at worst 33lbers for a turbo setup.
would i be able to use normal style gm high impedance injectors or ford racing 42lb mustang injectors (green tops) and splice on new connectors? will everything work fine if i do?
thanks in advance
try the gm 2.4 310 sc injectors, and i think the eco 370cc sc injectors are the same ohms
I will need to splice on new wire connectors correct? it looks like the 01's have a different injector connectors than the standard gm and ford styles? thanks. does anywhere on the net sell these clips or will i have to hit a junkyard? thanks.
-Brandon @ streetlegalcustoms
I bought my 310 cc injectors from www.injectors4u.com. They are the same as what came in the gm sc kit originally the part # is 25166922. They were only like $110 shipped for all four. I think they will plug right in for you since your car is an 01 and mine is a 01 build date but 02 model. Shipping was quick to.
Would an AFPR be needed on a 01 2.4L if you were running the reflash and say green tops or would the computer balance it out you think?
~Boost. Its what's for dinner!~
thanks for the reply, the problem is that I dont think the 310cc wil be big enough, were shooting for about 200-230 whp so im needing an injector thats about 42lb an hour, with stock fuel pressure using an hp tuner. with those 310cc would it be alright to use a rrfmu say a 3:1 unit instead of a hp tuner??? thanks guys.
-Brandon
anyone??
also is the hp tuner pretty much the best bang for the buck?
