The aeromotive afpr i got that bolts right onto the fuel rail touches the cables that open the throttle body plate... i put the cables over the throttle body and some times there is so much tension that the cable holds the throttle body plate open
Aeromotive P/N 13107
http://www.distinctdev.com/turboinstall/front_view%20(Small).jpg
^^ thats it while i was installing it, i can get a pic of it installed so you can see the exactly what i mean, but for those who understand my attempt of explaining this, is there a solution? relocation, modification to make these parts not be touching?
both the cruise control cable and the gas pedal cable are in the way...
did you try running the cables over the top of the fpr ?
also might try a small spacer under the cable bracket on the bolt closest to the fuel rail to lessen the angle going over top of the fpr
just a thought
I'd do what he said^^
I dont have that problem with mine. My throttle cable runs on top of my AFPR. Never noticed any rubbing or throttle stickage...
~Riki
SPONSORED BY: No one!
Car Domain Site
right now, they are running over the top of the afpr... do you guys have cruise control? cause that cable is the worse one...
if i put a spacer on the fuel rail, then wouldnt it be to far away from the injectors?
any other ideas?
no put the spacer on the throttle cable bracket
it is held down with 2 bolts , put the spacer on the bolt closest to the fuel rail
I run mine over top of it and I also no longer have cruise control in the way
what was your solution? the spacers?
i ran mine under the afpr.....and it works just fine.
*************Yea i spell liek wrong get over it*****************
** If i write in caps its cause im @ work and i can only write in caps cause the keyboard is a retarded CAPS only keyboard.**
