So Lost................. - Boost Forum
Sunday, May 21, 2006 9:31 AM
i've been searching for a turbo for a bit now and i understand a bit but not to the extent that i should which is starting to frustrate me
i have a 2.4 ld9
all im going for right now is roughly 260hp @ the wheels and i know the T3 Super 60 is always a great candidate for our motors as well but what trim/ar is gonna work for low lag and produce the #'s i want?
i dont care if doesnt hit full boost til roughly 3500rpm but would prefer full spool around 3000rpm
i apologise for having yet another post but i havent had any luck and this is my last result
thanks for your input and time
scot
Re: So Lost.................
Sunday, May 21, 2006 10:27 AM
The T3 super 60 will spool around 3k rpm or sooner. I purchased mine from down2turbo off of ebay it was the cheapest. I think you will be happy with it.
~Boost. Its what's for dinner!~
Sunday, May 21, 2006 12:26 PM
i got my turbo from www.ATPturbo.com and they are definatly good guys to deal with... the beat any price i could find as well not even 24hrs later after ordering it, it was sitting in my living room... thats fast delivery if you ask me... and that was from california to calgary... so it would be to the same for you scott...
here is one turbo which would probably put you into a good part on the turbo map... but if you even wanted to go to 300hp this would have to be changed but on the up side you would have quick spool up with this turbo....
T-Series T3 60 Trim
if you want somthing slightly bigger with maybe a bit more spool up time but has the flexability to go over 300hp if you ever decide to you could go with this one....
T-Series T3/T4E .58 45 trim
The First Twin Charged jbody
blue car (R.I.P) - 240whp @7psi..
silver car - 305whp 315lbs.tq @15psi (91 Octane) or 420whp & 425lbs.TQ @20psi (94 octane+Alcohol Injection)
All dynos run on a Mustang dyno
Sunday, May 21, 2006 12:38 PM
I'd suggest a t3/t4 but thats me...
if you need any help getting parts, cnfx can get you all the parts need... hit me up on AIM
LE61T PTE6262 Powered
Monday, May 22, 2006 11:11 PM
any other insight out there?
Monday, May 22, 2006 11:28 PM
Do you plan to run this on a completely stock motor?
-Chris-
-Sweetness-
-Turbocharged-
Monday, May 22, 2006 11:30 PM
Garrett GT2554R (aka GT25R), how much better is a ball bearing for him, or not...
Dual Ball Bearing GT25R Turbo assembly with internal wastegate assembly. .64ar turbine with 5 bolt exit. Very very Good response turbo for 4 Cyl applications. This turbo has a flow capacity of about 240HP.
Turbine
-Wheel: 53mm w/ 62 trim
-Housing: .64 ar
-Maps
Compressor
-Wheel: 54.3mm w/ 60 trim
-Housing: .80 ar
-Maps
98' Pontiac Sunfire SE
Tuesday, May 23, 2006 12:02 AM
Chris: this will be on the stock motor for the time being until i can get my other one built
Jared: is that 240hp supposedly at the motor or wheels and what psi is it efficient to and i would prefer it to be externally gated
Tuesday, May 23, 2006 12:16 AM
Ok so you want to hit 260 whp on a stock motor at stock CFM and efficiency basically...
From what I remember of PJ's maps and from my own research a T3 Super 60 is definitely a good buy for you... mind you I do believe PJ's maps showed 10-12 psi to be right around where the Super 60 is being its most efficient before the surge limit...
the reason I mention 10-12 psi is because a stock motor has only so much VE and CFM... and an LD9 with little to no mods will dyno at around 125 - 130 whp for a 5spd..
You want around 260 so 260-130 = 130 whp over stock...
Generally 10 whp / psi is what's needed but I can bet if you have a good intercooler setup and a good tune you can see more than that.... so I'd surmise you'd need 10-12 psi to attain your goals.
I'd have to see a compressor map of a super60 and run over the calculations again for a stock engine (estimating, as nobody really has real specs) to see... but I do believe from PJ's pervious calculations that the Super60 will give you the best powerband for the stock motor. Remember I'm talking a real super 60 not a T3 60-1.
Once you build the motor and raise your goals you will need a new turbo, though.
-Chris-
-Sweetness-
-Turbocharged-
Tuesday, May 23, 2006 12:24 AM
for the sites that u all left, those r just for the turbo, did u all get kits or what, do u kno where i could find a kit for a turbo or would it be easier to order parts ceperatly...? i need help too i want to turbo my 98 cavy ASAP
Tuesday, May 23, 2006 8:10 AM
I built my kit from scratch. There are a few companies on the .org but it's hard to tell you what your options are without telling us what engine you have. Also, why do you need to turbo your car "ASAP"??? Boost isn't something to rush into.
-Chris-
-Sweetness-
-Turbocharged-
Tuesday, May 23, 2006 9:08 AM
SweetnessGT wrote:I built my kit from scratch. There are a few companies on the .org but it's hard to tell you what your options are without telling us what engine you have. Also, why do you need to turbo your car "ASAP"??? Boost isn't something to rush into.
-Chris-
x2
Also, I believe you're referring to this thread (I made the maps, PJ elaborated ).
fortune cookie say:
Tuesday, May 23, 2006 11:00 AM
chris: for the true super 60 what is the trim and ar of it so i can go abouts looking,
and with the super 60 what will it be able to run psi wise before compressor surge cause im really wanting to hit that 260whp mark.
i will be running a HO manifold if that helps and i might try the secret cams and i already have my 62mm tb installed
i appreciate your help immensely
Tuesday, May 23, 2006 1:28 PM
how bout this?
DESCRIPTION:
Brand: Turbonetics / Garrett
Model: T3 (.48/.60)
Compressor A/R: 0.60
Compressor trim: "60"
Turbine A/R: 0.48
Turbine trim: standard
Flange type: T3
water cooling: Optional
Internally wastegatable: YES
RECOMMENDED APPLICATIONS:
4 cylinder engines with 1.6L to 2.0L engines with stock outputs of 100-160 HP
Tested for as much as 275HP
Tuesday, May 23, 2006 1:56 PM
I'm not sure you're quite ready to be thinking about purchasing a turbo...a little more research into how and why they work would probably be a good idea.
LAFNGAS wrote:chris: for the true super 60 what is the trim and ar of it so i can go abouts looking,
'super 60' is the trim. It's related to the inducer / exducer ratio of the impeller wheel. Since a 'super 60' turbo is judged by the wheel only, you can get it with whatever a/r you want...both compressor and turbine housings. For your app, I would suggest a .60a/r compressor, and a .63a/r exhaust. Some people get the smaller housings (.42/.48) to reduce spool time, but it will limit your power and top end. Mike K put 400+whp down with the .63 turbine housing, so there will be no need to upgrade that later. Also, my stock lil LN2 spooled 9psi almost instantly with a .63a/r/.60 60-trim, so lag will definitely not be a problem.
Still, as you can see in the thread I linked, I would recommend .63 T3/ 50trim T04E for your motor. This won't be much a hindrance right now (as far as spool time), and will let you run 400+whp later if you want.
You mentioned compressor surge as being related to max psi...not really a link there. You deal with compressor surge when you try to run a lot of boost from a big turbo on a small engine at lower rpm (or when you have a faulty BOV). Your "max psi" as you say will be determined by the rest of your system. The more you compress the air, the hotter it will become. With a better cooling system (big FMIC, alky/water inj), you can safely run more boost. You will also want to retard your timing when running with hotter air to help deter detonation. The biggest factor in how much boost and how much power will be your tuning, don't cheap out there, and don't rely on band-aids.
LAFNGAS wrote:how bout this?
DESCRIPTION:
Model: T3 (.48/.60)
Turbine A/R: 0.48
Flange type: T3
The turbo you listed is a 60 trim, very close to a super 60 (chances are that you'd never notice the difference). If you're planning on building your engine later, why get a little turbo that you'd have to replace? GO 50 TRIM
fortune cookie say:
Tuesday, May 23, 2006 4:45 PM
OHV: thanks for your help, it is greatly appreciated
Tuesday, May 23, 2006 10:31 PM
i dont have to turbo my car asap i just want to...who doesnt want boost....haha
Wednesday, May 24, 2006 5:24 AM
GO 50 TRIM
He talked me into it couple months ago lol.....
STREET ANTIX, it's coming...
