Do you need to support the engine to remove the lower motor mount. I need to remove it to remove the oil pan to tap for my oil return on my turbo. I know when i put the lower mount in i supported the engine on the oil pan w/ a block of wood but i cant do that cause i need to remove it. how do i support the engine without a cherry picker or something like that?
Shifted wrote:No, the upper mount and tranny will hold it in.
ya I left mine overnight to wait for the gasket... it was fine .... you have 3 other mounts holding it in ....
Lee
JDM Civic Hatch
mine was fine too.... on that note tho my upper mount was trashed... so trashed in fact that when i replaced it i had the engine jacked and supported with a strap where it needed to be to come out. that was 2" down and 1.5" back from where it needed to be for the new one!!!!!!
99 Turbo Sunfire GT | Ram 2500 | International Rollback | Mr Hanky the Suburban
i left mine for like 1.5 weeks with out a lower mount when i was putting my turbo in... it wont move... its all good
The First Twin Charged jbody
blue car (R.I.P) - 240whp @7psi..
silver car - 305whp 315lbs.tq @15psi (91 Octane) or 420whp & 425lbs.TQ @20psi (94 octane+Alcohol Injection)
All dynos run on a Mustang dyno
