hey i knwo it was in a post a while back .. well within this month i wanna say . it showed all the vacuum line hook ups for a turbo . can anyone help me ?
ok i have another question . i swapped out throttlebodies with the one from a 2.3 hi output engine . i think its 56 mm if i'm not mistaken . now i remember i had to T off the vacuum lines because the bigger throttlebody only had 2 vacuum inlets compared to the stock 3 inlets. what inlet do i use for the fmu and blow off valve . ? so i splice the blow off valve and the fmu vacuum lines together ?
FMU should use the FPR for its signal. blow off valve can use any of the others. EVAP perhaps??
oh ok .. got ya . thanks man
