Can someone help me out with this, I tossed the directions that came with my new horn, what is a good power souce to run from the horn to the steering wheel?
Battery is most definitely an excellent place. Make sure it's fused, and you run a relay so you don' t have to run massive power cable to it.
Beat it like it owes you money
wuts wrong with the wiring off ur stock horn?>
I dont know what wires to use, it is going on an aftermarket wheel
is it one of those annoying fog horn things?
No just a regular horn, once I removed the stock wheel and installed the aftermarket one the horn will not work, hence the need for a new horn
