Wiring extra battery - Does this sound correct? - Audio & Electronics Forum
I did a search and read a lot of posts. I will be installing a second Optima Blue Top in the driver's side left rear corner of the trunk - I will have a fuse in the engine compartment and one at the trunk battery, from the trunk battery I will add a new 1.0 farad cap then send power to my existing 0.5 farad cap, then to a fused distribution block, from there to the 4 channel amp and the sub amp.
why a marine use battery? would the yellow top not surfice?
Fact 1:
This post may contain misspellings, grammatical errors, disorganized sentence
structure, or may entirely lack a coherent theme.These elements are natural
to my process of writing, and will only add to the overall beauty of the post.
Fact 2:
true.
It would just fine, but I wanted the blue top for the color to go with the rest of the cars blue accents.
You know you can paint it right? Just cover the terminals with painters tape first.
Fact 1:
Fact 2:
true.
the marine top just has different terminals...it'll work just fine.
and your doing good up until the cap...throw those in the trash.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
First let me say that I believe you would be much happier with the results if you upgrade the big three instead of installing capacitors.
Now that that's out of the way. I believe capacitors should be wired in parallel. I could be wrong be I think wiring them in series defeats the prupose.
-Chris
Why through the caps in the trash?
I have been so focused on the extra battery that I forgot about upgrading the big 3. I already have a new ground ground from battery to chassis - I had to do that with the Blue Top Optima up front, I will do the rest later this week.
Thanks for the info
the caps won't help you....do the big 3, and the batteries, possibly an alternator in the future, but those caps are worthless.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Yeah, every single car or truck of seen with a cap, i just laugh cause they start playing there music and they do nothing at all. The way i see it, is that there a waste of money.
<img src="http://rage.webspiffy.com/images/sig.jpg">
let's not start a cap argument in here again...there's plenty of topics on that.
but your correct for wiring your battery, be sure to ground tha one in the trunk properly. use some 1/0awg if your not already.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
^^^^^ Your no fun
haha
