How much internal work would be needed to move the headunit up about... 1.5"? and if youve done it, can you post a picture if there was anything you had to move around in the dash?
thanks.........
Vice President - NEJBody
2007 Cobalt SS
2001 Sunfire (retired)
1.5 inches, hmmm, im guessing you either want it where the Hvac panal is or where your center vents are.
Well best thing to do is remove those 2 center dash screws and take a look for your self., the HU wires should have enough slack in them so you wont have to extend the harness. However you gonna have to see how you want to mount it. The stock, or after market mounting bracket might help, might not depending on where you want it. Some new holes may need to be drilled.
theres some metal cutting you will need to do in the back and a Whole lot of plastic cutting
