newb wiring help - Audio & Electronics Forum
newb wiring help
Wednesday, January 21, 2009 6:03 PM
i'm a total newb when it comes to car audio, can some help guide me. i want to wire up my front speakers to my amp. i have infinity 5.25 in there. i ahve a 2/3/4 chanell amp that i'm bridging. going to use 3 channels. help please
Re: newb wiring help
Wednesday, January 21, 2009 7:52 PM
we need more information. what are you bridging to the third channel, whats the amp and link us to everything. or post the specs
Wednesday, January 21, 2009 8:22 PM
Yes, please give us the model of the amp and we'll be happy to cover all your issues.
Thursday, January 22, 2009 4:41 PM
the amp is a dual xpa4100
Classification Class AB
Channels 4 Channel(s)
Output Power 4 x 50W RMS (20Hz to 20kHz) @ 4Ohm 1% THD+N
4 x 75W RMS (20Hz to 20kHz) @ 2Ohm 1% THD+N
2 x 150W RMS (20Hz to 20kHz) @ 4Ohm 1% THD+N - Bridged
Maximum Power 600W
Impedance 2Ohm to 8Ohm
Signal to Noise Ratio (SNR) 72dB(A) (Reference: 1 watt into 4 Ohms)
and i have a alpine eseries that i'm going to use on the 3rd channel
SPECIFICATIONS
Power Handling
Power Range: 100W-250 Watts
RMS Power Handling: 250 Watts
Peak Power Handling: 750 Watts
Dimensions
Mounting Depth: 135 mm (5.3'')
Mounting Diameter: 228 mm (9'')
Displacement: 0.055 cu. ft. (Front Mount)
Added Volume: 0.061 cu. ft. (Reverse Mount, Magnet Out)
General
Frequency Response: 29Hz-1000Hz
Thursday, January 22, 2009 6:02 PM
is that sub DVC? or SVC? im thinking that it is 4 ohm single voice. so if that is so then just run wires from your sub to the 3rd and fourth channel on the amp. use the positive on the 3rd channel and the negative on the fourth channel. then just hook up your fronts one to each of the remaining channel, obviously the left speaker to the left channel and the right speaker to the right channel.
but if its a DVC 4 ohm then im not sure what to do....
Friday, January 23, 2009 3:21 AM
its a SVC so that sounds good, going to give it a go saturday.....thanks
