box build help... - Audio & Electronics Forum
box build help...
Saturday, July 26, 2008 8:57 PM
ok im buy a new subwoofer and im building another box. the box will fit the power acoustik MOFO (i know alot of people dont like PA but dont bother me about it im happy with them, keep it about the box). anywas it need 2 ports that are 3inch by 6.75 long. my question in figuring out the box size is do i incorporate the port volume in the cu ft, or do i leave it out? same with the sub do i figure out the subwoofers volume(aproximate) and detract it from the boxes cubic foot? sorry if it make no sense.
Re: box build help...
Saturday, July 26, 2008 9:26 PM
this is what i have so far its at 2.375 cu ft with the sub and ports deducted. its an image from my student version of solidworks2007(the best 3d cad system ever, also 08 has way better image things)
Saturday, July 26, 2008 10:13 PM
another image from solidworks its the assembly im liking this look how do you guys like it?
Saturday, July 26, 2008 11:09 PM
thats looks like, kick A** set-up, That would be tight sub box.
Monday, July 28, 2008 4:10 PM
so no one knows the answer to my question?
Monday, July 28, 2008 4:39 PM
leave it out.
"I did it because I wanted to see what it would look like. You should be greatful that I even told you that it would look good. If your to dumb to use photoshop and change the color of your own car then you don't need to see it changed. I'm not going to give my work away. I'll sell the pic to you though for $15."-Adam Kalin
^^JBO is about not being that guy
Monday, July 28, 2008 6:20 PM
thanks!
Monday, July 28, 2008 7:36 PM
WHOA the port is going to displace inside your box. as is the displacement of the woofer. you will need to subtract the port and woofer displacement from your total volume in order to get a correct box volume. if you dont you are going to run a box that is far smaller in volume for the port you have and it is going to raise tuning and sound like booty hole.
Monday, July 28, 2008 7:52 PM
thats what i did and it was an approx. 2.375 cu ft which im sure i did the sub a bit big so i think ill be good thanks though its always good to know stuff. do oyu think it will be fine if its a little smaller then the targeted volume???
Wednesday, July 30, 2008 1:51 PM
how small are you talking? one way is to play it and find out lol
Wednesday, July 30, 2008 3:47 PM
the target was 2.4 and what i came up with is about 2.375
Wednesday, July 30, 2008 4:44 PM
with that much of adifference, it shoulnt throw your tuning off by more than around 5 hertz, you wont be able to notice the difference in 5 hetz.
98z24, lowered 2", aem intake, cat-back striaght pipes!, cop ligths in the front and rear, 18" liquid metal's, primer black, tint, full audio and video.
Wednesday, July 30, 2008 5:15 PM
not even. the ports are what are gonna change the tuning and a .025 cube difference isnt gonna make any difference whatsoever
Wednesday, July 30, 2008 6:51 PM
maybe I was exagerating a bit when I said 5 hertz, but it would make a difference, the point is, the difference it would make, you would never be able to notice.
Wednesday, July 30, 2008 7:15 PM
thanks guys
Sunday, August 10, 2008 8:42 PM
go with a different style box
Sunday, August 10, 2008 8:52 PM
joshua knaack wrote:go with a different style box
like what?
Monday, August 11, 2008 4:48 PM
Slot port FTW.
Slot Port Box Calculator - Compliments of RE Audio.
*2000 Cavalier sedan*
Monday, August 11, 2008 4:52 PM
^thats what i was gonna suggest..... i arn 2 circle ports for my 15s but it was casue i was limited on space and couldnt get a slot port tuned high enough
you will be happier with a slot port, or if u insist on a circle port invest in some aero ports
FDP 62MM TB, FFP Performance Chip, FFP Underdrive Pully, WAI, Hi Flow Cat, 2.5" Catback, Functional Ram Air Hood, Centerforce Dual Friction Clutch
Monday, August 11, 2008 6:50 PM
ok, I like the design of my box is there any way to calculate the size of the slot port for the box designed above ill post dimensions and such in a minute if anyone wants to help.
Monday, August 11, 2008 7:34 PM
Link To MOFO
Monday, August 11, 2008 8:01 PM
Use 3/4" MDF, not particle board, and definitely not 3/8" anything.
Monday, August 11, 2008 8:02 PM
whats wrong with 3/8? too thin? actually i think i ment to say 5/8
Monday, August 11, 2008 8:34 PM
Yes, it's too thin...it could possibly resonate causing distortion or cancellation issues. 3/4" isn't more than a couple bucks more than 5/8" either. Almost all custom boxes use 3/4" and some use 1". I always feel that when it comes to building a box, it's better safe than sorry...it really sucks having to rebuild a box after your just finished making it, trust me.
Tuesday, August 12, 2008 1:54 PM
mmmmmm 1". my dad built a box for his 15 inch l7 with 1" mdf. awesome theft resistor cuz the box is heavy as @!#$ now.
