amp turns off when playing a cd? - Audio & Electronics Forum
Thursday, March 06, 2008 4:49 PM
well, i finished wiring my amp, cd player, and subs tonight. i tested it out, and the amp turns off when i change the source to cd player, but works fine with the tuner. any ideas what the problem is?
Check out my build thread!
Re: amp turns off when playing a cd?
Thursday, March 06, 2008 7:17 PM
yea hook it up to the blue/white not blue......if you dont have blue/white then use the red wire....
Thursday, March 06, 2008 7:22 PM
most radios come with two turn on's - one for the amp and one for the antenna. you hooked it up to the antenna.
Thursday, March 06, 2008 8:59 PM
probably what they said but if not ...
check to see there isnt a short in the remote turn on wire as well. sounds like the max current of the remote turn on is being exceeded causing them to turn off. other option is run the remote turn on to a relay then power up the amp with that.
14.82 @ 97 mph
Thursday, March 06, 2008 11:57 PM
Viper98912 wrote:most radios come with two turn on's - one for the amp and one for the antenna. you hooked it up to the antenna.
winnar
Monday, March 10, 2008 10:29 PM
Jasonoshawaz24 wrote:probably what they said but if not ...
or just hook up the correct turn-on wire, common problem, why try making it seem harder than it is?
