Hey guys just wondering is there any way to reduce the vibration in the trunk. Got 2 subs put in the car finally and just wanted to see about the back end vibrating on the outside with the plate and all.
By the way i have a 2 door sunfire (2002).
Thanks in advantage.
also your plate is probably held on with two screws. I cool and easy way to stop that from rattling is put a small cloth behind it (cut so you don't see it) and put the bottom two screws in.
mclonedogmcwad wrote:also your plate is probably held on with two screws. I cool and easy way to stop that from rattling is put a small cloth behind it (cut so you don't see it) and put the bottom two screws in.
lol yea i put a styrofoam cup behind there and it doesnt rattle any more but for the trunk lid i would go with some sort of dynomat
Thanks guys, I will give that a try and see how it goes.
edead. its cheaper and works better than dynamat.
car audio noob since 1984.
foam filler is your friend my good man.
brown bread from b-quiet.com FTW.... its like dynamat but for the price of a dynamat trunk set up (150 bucks) you can get a big enough roll to do your entire car.
Another cheap why to do that is use Cardboard.
But Remember it must stay dry?
LOL...
I used a few foam pads out of a helmet that were left over, just duct-taped it on the back of the place, no rattles
For your license plate you can go like what i did and use rubber washers.Or you can put some styrofoam behind the plate.Also if your tails are a problem just tighten the @!#$ out of them.And for your trunk you can use dynamat.
Vote for my car for car of the month on www.v6z24.com..
