Hey I thought I'd chronicle my efforts for the benefit of others. Kinda give back to the community that's helped me a lot over the past few months.
This is my first stereo / amp install, and I had the following goals in mind:
1) The install had to take up minimum space. I must be able to haul stuff in the trunk
2) Minimize the showing of wires
3) Allow for the back seat to be still folded down
4) I like my donut spare
5) I also like my glove box and console
5) Nothing underneath the seats. My car is a convertible and god forbid it starts raining and I get screwed.
Equipment list:
1) refurb Kenwood DDX-7019 with Sirius and Navigation add-on
2) Memphis Audio 4004 (50x4) amp
3) Sony X-1S (250x2) mono amp
4) Polk 6.5" for the front.
5) Blaupunkt 6x9" in the rear
6) 2 kenwood 10" shallow subs for the trunk
7) Wiring harness and chime retainer
8) 4ga wiring to both subs, 12ga to the main speakers, 10ga to the subs
MA amp install:
I looked all over the net and couldn't find anybody who'd installed their amp underneath the glovebox.
If you look under the glovebox, you'll notice there is flat recessed surface perfect installing an amp.
The measurements are approx 16.5" wide x 7" deep (due to the blower motor) and about an inch recessed.
I cut and glued two pieces of scrap plywood (3/4" to 1" I'm can't remember) together so they went lower than the blower motor.
Here's a pic of the board half mounted to the amp:
You'll notice the amp is wider than the board. This required using a piece of steel bar from Lowe's and screwing this to the board (only one installed on the pic).
Then the two ends of bar were drilled, threaded, and screwed in with allen wrench screws for a stock look.
Board installed (glovebox view):
Board installed (underside view):
Amp installed:
head unit and accessories:
Again looking around the car I was looking for a hidden place to put the Metra chimes retainer, Sirius radio, and navigation brain.
Well there happens to be a great location just beyond the console near the firewall.
You can see it in the lower left of the following pic (the dusty part):
Well there happens to be a nice big gap here. there are some tabs here making me think GM wanted to put something here at one time but didn't.
Maybe on a different year/model. Ohh well more space for me.
Here's the same location with all the boxes and wires sticking out of it:
Hell of a mess and made putting the cover back on a nightmare.
End product:
The two wires you see are the USB cable and the audio in for an MP3 player.
The head unit itself was difficult only because I didn't cut away all the plastic supports before installing all the wires.
As a result, I had to use my Dremel and cut around the wires very carefully. So if anybody is installing a double-DIN radio,
please be sure to remove the back plastic and some of the underneath plastic.
Finally screwed in:
Main Speakers
The back speakers were a breeze, although I had a couple of speaker mount studs broken off due to upholstery shop carelessness.
This was fixed using some slightly larger machine screw, a nut and a locking washer.
Here's how they look dead on:
The front speakers were a pain. I purchased the adapters from
http://www.mjmautoinnovations.com/speakeradapters. They ship slow but the adapters are of high quality.
Installed with purchased adapters:
Unfortunately, unless your speaker is flush, they don't fit right. In retrospect, I should have bought some components instead for this reason. Luckily I was able to disassemble the adapters and use washers wrapped in electrical tape to mount them. It is a tight fit because the windows almost touch the magnet and the tweeters rest against the door panel. Ohh well live and learn.
Sorry no pic of this.
Subs/Sub Amp
I purchased a couple of Schose sub boxes from walmart only to find they were too big. So I pulled out my circular saw and went to town.
Smaller sub box:
Covered and filled with Great Stuff foam:
I don't think I'll ever use Great Stuff again. I guess most people use some sort of silicon caulk to seal the box. The stuff is a real PITA to get off of your hands.
Installed pic (it has a twin on the left side of the car):
The amplifier is a class D and is absolutely tiny (less than a sheet of paper). Basically I screwed it into some plywood and stuck it in the stock amp location on the left side.
Sub amp pic:
So that's my install. Looking at my car you couldn't even tell I had that many wires running through it. I'm sure I have left some details out, so feel free to post questions.
Ohh, in case you were wondering ... IT SOUNDS AWESOME. Top down 70 mph, and I can still understand lyrics. I am a happy man.
