I dont know what I am doing wrong..Heres how I have it wired..
Instead of using the actual ignition switch I just used a normal switched 12v source and instead of an engine ground I just used a normal ground( not an engine ground) that I have the lights connected to and I have the sender hooked up like it shows in the graph.
When I turned the car on before I wired the sending unit and the needle would jump all the way to the max. side (100+) and once I got the sender connected it did the same thing.
I dont understand what could be wrong unless I *have* to have the wire connected to the engine ground but a ground is a ground right?
I also dont have the ground on the far right connected to anything, its just a mounting bracket stud.
Kardain wrote:what brand of gauge
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
a cheap glowshift off ebay..
Sorry... can't help ya. Don't have and can't find online the wiring instructions for that gauge.
However, the Cav I just got has the same problem, so *listening*
From what I know though (using my Cyberdyne gauge in my Fire as reference), the positive is hooked up to a switched 12v source, the ground is to the OBD2 port bracket, so that shouldn't be a problem...
Unless the sender isn't getting a good ground. Take it out, remove the teflon tape and do 1 wrap only, reinstall.
BTW: Whats with the yellow/red/black labels and the red lines on the diagram?
Edited 1 time(s). Last edited Sunday, January 21, 2007 7:03 PM
