Power off the remote turn on? - Audio & Electronics Forum
Tuesday, November 21, 2006 8:46 PM
Would it be possibal to power something off the Remote turn on wire for the amp? I cant remeber if it is 12v or not. I am wanting to hook up some neons around my amps and I wanted to have them turn on when the amp and stereo is on. Any way to do this without the remote turn on wire if that wont work?
"Laying in bed one night, I said "Where did I go worng?". Then I heard a voice say "This is going to take a while..."
Re: Power off the remote turn on?
Wednesday, November 22, 2006 12:53 AM
nope only carries a half volt.
mecp gold certified
jason
gmto2nr
Wednesday, November 22, 2006 4:46 PM
Use a relay that works off the headunits remote turn on
LOL
Thursday, November 23, 2006 7:03 PM
jason norwood wrote:nope only carries a half volt.
Why does that not sound right.
-Seth
Thursday, November 23, 2006 7:58 PM
-Seth
its 12v maybe half an amp
just use a realy and the remote wire as the trigger
Thursday, November 23, 2006 8:40 PM
-Seth
That sounds better.
-Seth
Thursday, November 23, 2006 8:56 PM
thats what i thought. a relay is your best bet besides running a new wire from a switched 12v+ source
Thursday, November 23, 2006 11:06 PM
This idea worked for me. Right after I installed my sound system I used the remote wire to power a 15" blue neon that I have mounted above the box (out of view). Hell I even used the ground terminal on the amp for the ground wire from the neon tube. It works perfectly and has worked now for nearly 5 years. Go for it.
Thursday, November 23, 2006 11:09 PM
Ok, thanks for all the ideas, Guess I just need to hook it up and try it.. I am trying to power neons btw.
Thursday, November 23, 2006 11:16 PM
Take note.. I only have one hooked up.. and it works fine.. I don't konw how many you intend on hooking up.
Thursday, November 23, 2006 11:26 PM
Note taken, I will try one... and if that works then mabey 2
Friday, November 24, 2006 12:26 AM
Whatever wrote:Use a relay that works off the headunit's remote turn on
x2 If you're going to use the remote wire, do it the right way (otherwise you risk burning something out)
Amps have an internal relay that are activated by the remote wire... what you have planned is no different
