Wiring Harness Issues... - Audio & Electronics Forum
Friday, October 06, 2006 7:30 PM
First and foremost, I have searched and read the sticky several times but my questions were not answered, so now...I ask.
I went today and bought everything I needed to do a headunit install and actually got everything in and working perfectly, or so I thought. After I put everything back together, I noticed that my Gauges and HVAC werent lighting up...not the whole cluster, just the gauges.. First thing I did was check all my fuses...every one, inside and under the hood and they were all fine. Then I ripped the dash back apart and checked all my connections and they were fine. Checked here, everyhting I searched came up "fuses", which were fine. As a last ditch effort, I put the stock radio back in and what do you know...everything worked perfectly! Now, I bought a Scoche GM035 harness for 2000-2003 Tracker, How do I get my gauges and HVAC lights to work? Is there somehwere I need to wire the Illuminaton/Dimmer wire too, because there is no place on my new deck to wire it to. Many thanks...
Nate
Re: Wiring Harness Issues...
Saturday, October 07, 2006 5:34 AM
Yes. I would start by buying a harness for a 03-05 Cavalier. What head unit are you running? Most aftermarket units have a dimmer/illumination wire. It's typically Orange. The stock harness dimming/illumination wire is grey.
Saturday, October 07, 2006 6:52 AM
Are those the only lights inside not working? Because all dash/interior lights are on same circuit. Check to mke sure the orange or ornge/white wire are grounding out anywhere. Also notto overlook the obvious but make sure your plugging in the dimmer switch when you put dash together.
Saturday, October 07, 2006 7:19 AM
And make sure the dimmer knob is turned up
Saturday, October 07, 2006 8:38 AM
All the idiot lights will come on, and the dome light still works off the dimmer...its just the tach, speedo, Fuel, and temp gauges that dont light up
Saturday, October 07, 2006 12:53 PM
nm, turns out my illum wire was grounding out
Tuesday, October 10, 2006 2:18 PM
yeah, suck huh, I have my dash pulled apart right now and i was going to put and aftermarket deck in thought i could use my brothers harness from an 94 cavalier...wrong....so i go to best buy and ask them about it guess the new radios have some RDS or something in it. So a bunch of the information is stored in the stock deck and like the door chime wont work they said all your gauges wont work except speedometer and the fuel one if your not low on gas.....so what im trying to say what i just figured out is that we need to buy a 120 dollar harness. that is how i stumbled upon this
sucks huh?
Tuesday, October 10, 2006 8:14 PM
GlowingCavy wrote:yeah, suck huh, I have my dash pulled apart right now and i was going to put and aftermarket deck in thought i could use my brothers harness from an 94 cavalier...wrong....so i go to best buy and ask them about it guess the new radios have some RDS or something in it. So a bunch of the information is stored in the stock deck and like the door chime wont work they said all your gauges wont work except speedometer and the fuel one if your not low on gas.....so what im trying to say what i just figured out is that we need to buy a 120 dollar harness. that is how i stumbled upon this
sucks huh?
Uhm, no. The only part of that that is true is the door/seatbelt chimes will not work. ALL gauges, dash lights, air bags will work normally. Read the sticky for more information.
-Chris
Tuesday, October 10, 2006 9:34 PM
70-2003- 15-20 dollar harness is all that's needed!
1st 1st gen on air.....
Tuesday, October 10, 2006 10:05 PM
sucks huh?
You got raped in the ass without lube. Sideways.
Wednesday, October 11, 2006 7:24 AM
^^^^ lol
Who needs a sig?
www.sinisterimages.com
Wednesday, October 11, 2006 7:48 AM
dood just give it a smack on the above.... worked for me
"Silver 2001 Cavalier z24 5 speed 2 door sunroof and power everything "
AEM Short Ram Intake
B&M Short Throw Shifter
