head unit replacement - Audio & Electronics Forum
Wednesday, September 27, 2006 7:30 PM
does anyone know what kind of installation kits, wiring harnesses, etc. i will need to install http://cgi.ebay.com/PANASONIC-MXE-CQ-C7413U-MP3-WMA-Motorized-Face-NEW_W0QQitemZ250032657612QQihZ015QQcategoryZ50560QQssPageNameZWDVWQQrdZ1QQcmdZViewItem in my 2001 cavalier.
i know that i would need some sort of interface (heard it called different names) to keep the tones that tell you when the keys are in the ignition and all that. but i dont think that all that is going to be necessary to keep. plus i dont really have the money to but one and have it installed.
Re: head unit replacement
Wednesday, September 27, 2006 7:49 PM
You need a mounting kit, wiring harness, and an antennae adapter for that car. I reccomend METRA kits as they seem to have the best all around quality. There is an interface you can get to retain your door chimes and what not but that is not necessary and is expensive. I've heard people say if you dont get this harness you will have other problems with your vehicle which is completely untrue. Its just there way of selling a $100 harness. The part numbers are harness- 70-2003 (lose door chimes), kit- 99-3301 ( ISO mount kit but looks clean in the dash), ant adapter 40-GM-10. There is not a switched accesory wire in the factory gm harness so you can either tap accesory off the 25 amp wiper fuse, cold side, or get a fuse holder and tap off the big brown wire in the ignition harness. The dash dissasembly instructions should be in the kit.
Wednesday, September 27, 2006 7:52 PM
the metra kit that retains the factory door chimes retains the switched +12V.
Desert Tuners
Wednesday, September 27, 2006 8:01 PM
yeah but its around $100 as opposed to the one i stated thats $19.95 gives ya a different option, just lose factory door chimes and switched acc
Thursday, September 28, 2006 6:28 PM
ok i understood what you were talkin about until you started the electric stuff. this is my first install of any kind and i pretty much know nothing.
is this the kit youre talkin about? - http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=250012655432
could you send me a link to the others, please?
Thursday, September 28, 2006 8:26 PM
To be honest, you are better off going to an audio store as opposed to buying off ebay for the wiring and kit. This way, if you have a problem or issue, you can take it back. For example, I work for Circuit City---if something doesn't work (like a harness or the kit is incorrect) I would sell you the correct one and exchange it. Ebay, on the other hand, you have to ship back and all that hassle. And the kit is only $20.
As for the door chime module....If you want to retain your factory door chime, go for it. If not, no big deal. I would double check the FAQ on the top of the page to see what other people suggest though, since I have a 97 and I have not worked on a 2000+. Also, I know you need that module if you have OnStar to retain that as well.
Sam
Ban low-performance cars, not high-performance ones.
Wednesday, November 15, 2006 8:48 PM
i just tried to put it in and it wont turn on..
there is no room back there for the wires and it sits up really far. so i figured i would mess with it later so i left it. i put everything back and hook up the battery and it wont work...
i got a metra wiring harness, and the mounting kit is fine, and the ant adaptor is fine. something has to be wrong with that wiring harness..
i plugged the car wire thing into the wiring harness and soldered all those wires into the plug that came with the HU.. and it doesnt work.. im very angry right now.
Wednesday, November 15, 2006 11:18 PM
take it to the professional or at least someone you know that has done a radio install..
goodluck
GOT ECOTEC?
Thursday, November 16, 2006 12:13 PM
email me, i have a full how-to guide i can send you with photos.
this useless post brought to you by the alcoholic known as LUNDiS
Thursday, November 16, 2006 12:45 PM
the red wire (acc wire) has to be run from either under the column or from the drivers kick.
1st 1st gen on air.....
Sunday, November 19, 2006 3:43 PM
I know its kinda expensive to go buy an interface, but I bought one for my Cav and a stereo harness and had no problems with the install, works great to this day, the interface is only 3 wires, RED +12V, YELLOW ACC. and BLACK GND, wire it inline with the stereo and there you go.
We Ride Together, We Die Together...... J-Bodies For Life!
SPONSORED BY: Showstopper Tuning, JM Graphics
2003 Cavalier LS Sport "SHOCKWAVE"
Sunday, November 19, 2006 6:53 PM
He has an 01.... so the red wire on the harness is not used. You actually have to run a seperate turn on wire. An easy solution is using the windshield wiper fuse, or the orange wire on the ignition harness. Please fuse the wire too.
