Yellowtop vs. Bluetop - Audio & Electronics Forum
Saturday, October 22, 2005 3:48 PM
i used to think they were the same battery, just with marine style posts on the marine batt, but at while looking at the spec sheet i noticed that the yellow offers the D34/78(750 cranking amps) as its biggest batt, while the Bluetop offers the D31M(900 cranking Amps). Unless the D31M is the same battery as the Batt that appear under "Commercial"... the D31A and the D31T(whatst he difference between these two? they have the same specs)
now i'm fairly certain that the D31M wouldnt fit under the hood(its an rsx-s, maybe it will..doubt it.), but the other two or three batteries i want to put in the trunk would definatly fit. Blue definatly matches with the blue/silver theme i have planned for the car.
thanks in advance
Re: Yellowtop vs. Bluetop
Saturday, October 22, 2005 3:57 PM
get the group 31 yellow top, lol
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Saturday, October 22, 2005 4:03 PM
the 31A or 31T? whats the difference? i'm assuming it IS the same battery as the 31M Bluetop then?
Saturday, October 22, 2005 4:37 PM
yellow are deep cycle, blue are generaly hybrid (yellow are available hybrid as well - starter/deep cycle)
Causa latet vis est notissima
DIY Clear 03+ Headlights
Saturday, October 22, 2005 5:09 PM
Grimor wrote:yellow are deep cycle, blue are generaly hybrid (yellow are available hybrid as well - starter/deep cycle)
not true, yellowstops are hybrids two. as far as i know, the only difference between the blue and the yellow is that the blue has marine style posts. my question was to the biggest sizes available.
hybrids TOO, not two.. XD
Sunday, October 23, 2005 8:22 PM
SomeGuy wrote:the 31A or 31T? whats the difference? i'm assuming it IS the same battery as the 31M Bluetop then?
i cant find the answer to this anywhere..
Sunday, October 23, 2005 9:26 PM
have no clue homie...call optima
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Sunday, October 23, 2005 11:07 PM
from what ive heard, the only difference between all the different optimas is the power they have while the car is OFF, when its running they perform the same.
Monday, October 24, 2005 6:15 AM
when your car is running you shouldn't be drawing from your bat much at all if any. your Alt handles the running power demands.
Thursday, October 27, 2005 10:19 PM
Optima batteries are pointless. The whole point to optima batteries is to eliminate corrosion. Optima batteries have a gel, while regular batteries have the typical liquid acid. The gel cannot leak through the terminals as easy, hence less corrosion. Dont waste your money on these batteries and go grab yourself an Insterstate battery. If your willing to dish out that much cash on an optima, the insterstate should be no problem.
Thursday, October 27, 2005 11:12 PM
Eh? I use an optima for the deep cycle feature.... nothing to do with corrosion.
Friday, October 28, 2005 6:16 AM
rick weissbach wrote:Optima batteries are pointless. The whole point to optima batteries is to eliminate corrosion. Optima batteries have a gel, while regular batteries have the typical liquid acid. The gel cannot leak through the terminals as easy, hence less corrosion. Dont waste your money on these batteries and go grab yourself an Insterstate battery. If your willing to dish out that much cash on an optima, the insterstate should be no problem.
you're wrong, optima batteries are not GEL types.
Friday, October 28, 2005 10:13 PM
what is the website for optima batteries?? i'm also looking to buy one.
http://www.1st-optima-batteries.com/
scroll down to the yellow section. the difference seems to be the 31T has top studs while the 31A has top posts. I don't konw what that means though.
Sunday, October 30, 2005 7:14 PM
deep cycle = longer life without use
Sunday, October 30, 2005 7:35 PM
Actually, they are refered to as "deep cycle" batteries because they can be drained, or "deep cycled" many more times than a standard battery and still retain a full charge when they are recharged. Nothing to do with how long they hold a charge without being used. All batteries slowly lose their charge if they sit.
-Chris
Sunday, October 30, 2005 7:47 PM
If So why is it my brand new OEM style acid core batt. would only run my 2 Viair 450's, 2 rockford 1200w amps, all the LCDs and neon and strobes for about 30 min max where my fully charged yellowtop will run for nearly 8 hours no problem?
Also Im not shure what style yellowtop I have but it has top posts and side mounts, I use both...
Monday, October 31, 2005 5:44 PM
Optima's are actually made by Interstate.
I bought my red top from an Interstate guy that sells blemished batteries and thats what he told me.
Friday, November 04, 2005 11:06 AM
and interstate is actually owned by johnson and johnson. i work with a guy that used to work for interstate. most @!#$ about batteries is marketing.
Friday, November 04, 2005 12:41 PM
deep cycle batteries are the slowest charging - and discharging (ie. transient response) type of battery.
I usually try to avoid using them. I only have them in my car now because i already owned them..so i wasn't gonna go buy all new batteries, lol.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
