Lights Dim - Audio & Electronics Forum
Lights Dim
Monday, September 05, 2005 9:21 AM
ok, i just hooked up my 3 JL Audios 12 inch......no amp or box or anything i was just testing to see if they worked. i just ran a wire in my trunk to my 6x9s. when they hit the lights dimmed. what will i have to buy so this wont happen??idk if you guys need any other info but if u do just ask. thanks
FOR SALE: (5) '95-'99 Z24 Rims
Re: Lights Dim
Monday, September 05, 2005 9:31 AM
a bigger battery or capacitor
Look Im Premium Now Give Me More Post....
Re: Lights Dim
Monday, September 05, 2005 11:48 AM
better battey, bigger alt, big3. caps arent worth it
Re: Lights Dim
Monday, September 05, 2005 5:51 PM
whats a big3? and how much is a new alt?
Re: Lights Dim
Monday, September 05, 2005 10:24 PM
big 3 is wiring between chassis, battery, and alternator. 4 gauge is recommended by most people apparently.
no idea on how much alt is.
Re: Lights Dim
Tuesday, September 06, 2005 12:59 PM
so your lights dim without an amp at all?
what did you wire your three 12's to again???
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Re: Lights Dim
Tuesday, September 06, 2005 1:02 PM
My first guess - since you're not using an amp, is that whatever you have the subs hooked up to isn't made for the load that you're hooking it up to (e.g., your load is too small), and it's causing a current draw that's pretty large (even though it may not sound like it with the subs). There's no way the lights should be dimming w/o an amp otherwise. Unless you have some serious alternator/battery problems right now.
Re: Lights Dim
Tuesday, September 06, 2005 1:45 PM
my car has no problems is just that when they would hit the lights would dim....i guess because they were hooked upto the same wires that run to my 6x9's :p
Re: Lights Dim
Tuesday, September 06, 2005 2:02 PM
yeah y did you wire 3 12's to a 6x9 for. you do know thats not good for your headunit right??
Re: Lights Dim
Tuesday, September 06, 2005 2:08 PM
3 12's....a pair of 6x9's..and some front speakers.
ALL RAN OFF THE HEADUNIT!!???
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Re: Lights Dim
Tuesday, September 06, 2005 5:31 PM
well im glad you guys told me....i didnt know. what are u supposed to wire them to? lol im stupid i know. just let me know what i need to do.
Re: Lights Dim
Tuesday, September 06, 2005 5:43 PM
did you wire them in paralel? (aka, ran more than one speaker on a single channel)
If you did, you lowered the indepenance of the speakers.
Example, two 4 ohlm speakers in paralel would be 2 ohlm. The lower the indepenance the higher the wattage and higher the power draw. The problem is that you head unit can't handle the higher wattage and will burn out your op amps.
btw, this is how they get those high wattage rattings for amps.
