wasnt sure where to post this, and i used the search but to no avail. heres my problem. i have the keylessentry w/trunk lid. when i press the trunk release button, the trunk release does it more than once, making a machine gun sound. the lid opens but the electronic lid keeps doin it for 2-3 seconds more. any tips, or explanation on this is much appreciated
Having a Z is close enough to having an import.....
hmm no clue...sounds liek a real problem
lol thx anyways Machzel08. although the trunk release still functions as a trunk release im just a bity annoyed of it doin it a few more times after i pressed it once.
Sounds like possibly a sticking solenoid.
Sponsored by:
JLCaudio.net
No, more like a sticky remote button....
New Picture comming this summer.
your remote might send multiple presses as long as the button is pressed or help down, have you tried a new battery in the remote? Most of the systems I've seen will only hit once for each press, some cheap ones may just spam a series of hits to make sure the trunk opens. Do you have the system setup correctly? some may use a negative system (remote on the NEG side of the line) instead of on the POS
Causa latet vis est notissima
DIY Clear 03+ Headlights
trunk pop needs replaced, if it was a battery it wouldnt do it close to the vehicle or other things wont work also, is it fact or aftermarket?
