Well i did something dumb ! Got the battery cables backwards and try to start it . Everythimg works but no fire i chamged the ignition module and the coils and i have the 2.2swap. By the way it is a 97 z24 all forgef internals turboed but everythimg works but no fire if u all could help out it would be great all and all the fuses are good unless there is hidden ones i cant find i changed the inline between the starter and alternator which was blown so idk
mabe you burned the starter
It turns over just no fire from the coils
check ur fuses and for power to coils, fuel pump fuse/relay
Everything is good the module getting power and the fuel pump has pressure just not no spark leaving the coild wonder if it could be the theft system because wen i tur the keynto the on position the light stays on and doesnt go off
