ecm swap now theft-lock problem - Third Generation Forum
Thursday, September 10, 2009 7:46 PM
ok i just came home after tryin my free eco 5 speed ecm seen im still useing my auto ecm seens i did my 5 speed swap so i was at my dad trying to get my 5 speed ecm to work i got on here and foun out how to do the theft-lock re-set
to do the theft-lock relearn i
Start the car and let it die, then leave the key in the "run" position for 10 minutes. Turn the car off and start it.
will this work on the 03 ecms i hope i rally want to get rid of the x-mass looking light up gauges in my dash from runing a auto ecm with a 5 speed lol
Re: ecm swap now theft-lock problem
Friday, September 11, 2009 10:26 PM
well its safe to say it works Start the car and let it die, then leave the key in the "run" position for 10 minutes. Turn the car off and start it i did this to try to put my 5 speed ecu in to find that it was a ecu for abs and i wanted a 5 speed non abs ecu
Saturday, September 12, 2009 5:40 PM
what do you mean let the car die? do you mean turn the switch back and then turn it back over or do you mean drop the clutch and let the car die?
im having problems with my ecotec swap ecu's not working also. i still have my ecu from my 2.2 ohv motor in the ecotec. i put the ecotec bcm in under the dash and all and my ecotec ecu still wont work. the car wants to start but it acts like its not getting fuel.
help me out
thanks
Saturday, September 12, 2009 11:19 PM
start the car or try to start the car let it run if it starts it should run for 30 sec if not crank it a few sec then just leave it alone with the key on
leave it with the key on for 10-15 mins then turn it off and start it up should not thow the theft lock no more and should relearn its self it worked on my eco 5 speed ecm but the ecm has abs
now if i can find a ecm thats for ecotec that is a 5-speed with out abs ill be set lol
Sunday, September 13, 2009 3:03 PM
man to bad you didnt live closer to me jeff.... i could use hptuners to reflash your auto ecu to a manual so it will work with out abs..
Sunday, September 13, 2009 7:06 PM
hey man were are u im allways down for a road trip lol i like to have my speed limiter moved up and have the auto and abs stuff turn off may mess arond a little with the computer how much would it coust ant it like 50.00 a credit i really like to move my speed limiter im scared of topin out in the 1/4 on stock speed limiter
Sunday, September 13, 2009 7:21 PM
pm me man....
