I need to get my rotors cut and change my brake pads for the 1st time since I got my Cavi. What socket size do I need to remove the spindle nut ?? Thanks for any help.
Ipud wrote:We put Jap Traps on cinder blocks around here. We don't wave the American flag for novelty
I proudly own American cars, nothing else....
Removing that nut wont help you remove the rotor and caliper. There are 2 allen/trox head bolts on the backside of the caliper.
![](http://img267.imageshack.us/img267/7743/461470747661378e766ao.jpg)
its an old concept. time for something new to take the reigns. - Z yaaaa
What he said ^^^ and your getting the rotors cut? you mean get them turned? I'd just replace them, Its really not much more, and then you'd probably get a warranty with them for any future problems.
Un do the caliper and lift it up and the rotor pulls right out. Bring it to the salvage yard to make up a bit of the 5 dollar price difference between new and turned rotors.
Sponsored by:
Kronos Performance
Yes I meant turned. Sorry for the retard question, I'm used to old school spindle and rotor setups with a castle nut / cotter pin assembly. Thanks for the advice, I checked with Napa and they have a new set for $ 25.00 each new, and the cheapest place that will turn them is $ 20.00 each! I'll just go with new. Thanks again!!
Just for the record thats a 32mm nut!
jason norwood wrote:Just for the record thats a 32mm nut!
Not on all axles. Most use a 30mm.
yes, 30mm. My omni has a bigger spindle nut that the j body lol , 32mm.
I personally will never have a rotor turned. Not worth it. The Price difference is very minimal.
Ive seen after having them turned that they "warp" faster and need to be replaced at that point any way.
Doesn't matter what car, If I do the brakes, the rotors are being replaced.
