Eibach Pro-Alignment Kit Needed with my New Set-up. ? - Suspension and Brake Forum
Tuesday, May 03, 2011 5:44 PM
Hey i'm going too be getting Tokico HP Blues on Eibach Pro-Kit on my 2003 LS Coupe Z24* do i need to get one those or my Alignment just need a normal alignment. ? Thanks Guys ..
Re: Eibach Pro-Alignment Kit Needed with my New Set-up. ?
Tuesday, May 03, 2011 6:05 PM
not needed. just go to a good alignment shop afterwards. most likely you'll just need a front toe adjustment.
typically on these cars camber is uneffected when lowering. you really need to be SLAMMED for it to be out of spec enough to require something like that. or have been in an accident with frame damage.
Edited 1 time(s). Last edited Tuesday, May 03, 2011 6:06 PM
Tuesday, May 03, 2011 6:44 PM
Jon D wrote:not needed. just go to a good alignment shop afterwards. most likely you'll just need a front toe adjustment.
Thanks A lot ya im lowering on pro-kit n stock shocks n struts an alignment is great so guess i'll just have too see how it rides after my Tokico HP blues n Eibachs are installed together, but thanks wasn't sure if i needed it Thanks man.
Tuesday, May 03, 2011 6:49 PM
opps sorry Lowered not lowering, i will be lowering on Tokico HP Blues all Around with Pro-Kit Eibach's, the stocks ride over but u can tell its not proper certain times, my Buddy has a 03 as well and he has tokico HP blues on pro-kit n rides just Mint .. and nother buddy has sportlines on his 03 and rides about the same but sportlines low i dont like the slammed look well i do but 1.4 looks slammed too with 17"s maybe not slammed but pretty low, thanks for all your help tho Guys. Cheers
