Im not sure if this even makes since but, does anybody make poly subframe bushings and rack and pinion bushings for our cars. I cant seem to find any info. Thanks.
subframe bushings? hmmm... well i cant say with any certainty if they're are actually any bushings that go here because amazingly this is actually one part i have never removed.
same goes with the rack...
i dont think there are any poly bushings for them if they even have bushings. at least in my 7 years here i have never seen nor heard about any...
only bushings i am aware that we have our engine/trans mounts, rear trailing arm, control arms, and sway bar end links.
Stand in the corner and SCREAM with me!!!!
O ok well that takes care of that lol. I havent pulled it apart but I will here pretty soon. gonna put my aluminum ctrl arms on and re[aint the subframe and clean up the rack a bit b4 the engine goes in for the last time... I hope.
Any ideas on where to find busings to replace the ones from the IRS swap? I grabbed the parts from an alero and it could certainly use some refurbishing before I put it on the cavy.
Sig'less since '02!
Energy Suspension may have a kit for the rear irs from the Nbody and Polygraphite may have some too.
You'll have to use both the Alero reference and GrandAm GT reference for the bushings for those cars.
Good luck.
Misnblu.com
Newbie member since 1999
Thank you Dave and JBO!
