Does anyone know the part numbers for the wilwood pads/rotors for the big brake kit? And also the pads/rotors for the rear with the Baer kit? I got 52k on the brakes and its finally time to change them
I don't expect there's any part number for the rotors since they need to be custom machined to fit. Best to contact Baer.
Wilwood part numbers are on their website, look under the Jbody kit, ALL part numbers for the kit are there, right down to the washers
Wilwood Parts
-Rotors
-160-7103 Right Side
-160-7104 Left Side
-Pads
-15Q-7268k Axle Set
-Shim/Anti-Squeel Shims
-300-8259
Does anyone know if i need new bolts/saftey wire? Or can i reuse it?
As for the Baer rotors/pads i contacted them but no responce yet!
You should replace the safety wire. Bolts should be fine since they are not torque to yield
FAST2.4 P wrote:What calipers do those use. I need the actual part number.
Wilwood? The caliper they use is a DynaPro, part number 120-7327... not a cheap piece. $250 easy, each.
I now have a problem.. i got 3 out of the 4 pistons pushed in and i cannot get the last one in... Now there is fluid coming from the boots. Now what? Do i need new calipers?
