brake questions - Suspension and Brake Forum
brake questions
Wednesday, April 11, 2007 9:11 PM
ok i was wondering if you switch to drilled and slotted rotors do you have to adjusy anything like with your calipers or what because i was told those rotors are thicker than normal and has anyone ever bought from powerstop brakes before?
Re: brake questions
Thursday, April 12, 2007 3:57 AM
if you depress your pistons in your caliper, the pads actually open up pretty wide so if those rotors are a little bit thicker the oem rotors, then just take off the caliper and seperate the pads more
Re: brake questions
Wednesday, April 18, 2007 6:14 PM
the rotors are not thicker than factory, they cannot be. there is no modification possible to the calipers to allow a thicker rotor (that is safe anyways). I buy drilled & slotted rotors all around, and they always fit right on. be ready to replace them sooner, the rotors normally get a bunch of tiny stress fractures around the cross drilling.
Re: brake questions
Thursday, April 19, 2007 8:14 AM
Modern pad designs don't need slots or holes to get rid of outgassing. These rotors fail more quickly and are for looks only.
-Vincent K.
1998 Z-24
www.thscc.com
http://www.j-body.org/members/vkz24/
"Racecar spelled backwards is still Racecar"
Re: brake questions
Thursday, April 19, 2007 3:39 PM
VKZ24 wrote:Modern pad designs don't need slots or holes to get rid of outgassing. These rotors fail more quickly and are for looks only.
i agree 100%, but they do look nice.
Re: brake questions
Friday, April 20, 2007 10:06 AM
Well I'm braking from 115+ MPH about every 2 minutes during a 20 minute session on track so how the brakes "look" aren't high on my priority list. Mostly ricer boyz show up to a track event with drilled and slotted rotors. I had them when I used to show my car, but I cracked a brand new pair at my first track event. That was the last pair I bought.
-Vincent K.
1998 Z-24
www.thscc.com
Re: brake questions
Friday, April 20, 2007 1:57 PM
last i checked those rotors state right on the box/slip that racing voids warranty, and not what they are built for. if you are doing that, you need to do a brake upgrade, i would recomend BAER, they have 13"fron, 12"rear disc conversion with calipers, teflon coated stainless lines, master, e-brake stuff and everything that retails for $2500, so you should be able to get it for slightly under $2000 if you have a shop around you that does business with them.
Re: brake questions
Tuesday, April 24, 2007 11:22 AM
John Benham wrote:last i checked those rotors state right on the box/slip that racing voids warranty, and not what they are built for. if you are doing that, you need to do a brake upgrade, i would recomend BAER, they have 13"fron, 12"rear disc conversion with calipers, teflon coated stainless lines, master, e-brake stuff and everything that retails for $2500, so you should be able to get it for slightly under $2000 if you have a shop around you that does business with them.
I’m well aware, and I'm way ahead of ya. I built my own custom kit (like Baer’s) with PBR calipers from a ’95 ZR-1 Corvette and custom 2-pc front rotors.
-Vincent K.
1998 Z-24
www.thscc.com
Re: brake questions
Tuesday, April 24, 2007 3:20 PM
