Come on guys lets make a list to compare those Air Compressor products.
5 Gallon Tank @ 175 PSI
Viair 380c - ?
Viair 450c - 16 mins
2x Viair 450c - 8 mins
Viair 500c or 550c - ?
Oasis XD2000 - 22 seconds
Air Zenith - ?
You only have one posted.. for the 480c.
What do you mean by "most"?
You cant say cuz u dont want to lose money...
Theres times posted for the 380c as well...kind of disappointing though.
Checked the ABS site again, I relaized I didnt look carefully, was only viewing those new products for September.
Anyway yeah it was disappointing. Thats the reason Im starting this thread to help other people. So they should be aware about that.
Im glad you did...I was hoping of better times from that compressor since im getting it with the kit.
I figured....I Wont be hitting switches for 10 minutes at a time, unless at a show or something like that. Either way I'm sure the 380 will work fine. And maybe even 2 380s will be even better.
My 2 450's fill my 5 gal FROM 0psi-145psi in just under5 minutes.
When my pressure switch hits 110pis and my compressors kick on , they recover in under 2mintues.
That is fine for me, and I usually have them running 100% of the time I drive, I'm switch happy. Even at 0psi, they fill it enough to lift my car for driving in a matters of seconds. I never let it go down to 0psi, only when I'm moving stuff around and I unhook the tank.
My Myspace Page
Viair 380c - 14min from 0-200psi
Viair Dual 380 pack - 7min 0-200psi
Viair 460 - 6 min
Viair 480 - 10 min 0-200psi
Viar Dual - 480 Pack - 5 min 0-200psi
Viair 500c - 4min
Viair 550 - 4min
Hope this helps out
my 480 dosent take 10 mins...i can tell u that....maybe 7-8 or so
and with the 480 and 380 on a 5 gallon, takes about 4-5
Those are right from viair website on fill times.. Those are also 0-200psi ratings
www.viaircorp.com
2 100CF SCUBA's regulated
5gal tank
from 0-280PSI = 2 Seconds
dosent drop below 250 when pan-cake-ing
Ill NEVER go back to compressors, the only compressor ill have is 1 hidden AZ for backup only!
