ShiftyCav wrote:thats probably the dumbest thing i have ever heard. you should take that serpentine belt and wrap it around your neck.
Jace Evo2 wrote:I've had a set of Brembo slotted brakes for about a year now and am very satisfied. None of the coating that they have will last for very long, Powerstop or Brembo, atleast on the lip. The part still in contact with the pads stays in great shape and still looks great to date.
Matt: True slotted and drilled rotors don't do much more except allow the rotors to cool faster, which can reduce rotor fatigue and "warping per say" tendencies. It's all about the pads that you use. I've used a set of Akebono Pro ACT ceramics and they increased stopping power greatly in combo with the Brembos. Plus they do look pretty sick lol!
I'll post a pic later when I get off of work of how they look after a year of care and use.
FROM THE STICKY !!!! wrote:#1 Slotted or Crossdrilled rotors.
These rotors both accomplish the same basic things. Contrary to popular belief, slots and drill holes DO NOT help cool the rotor. They simply allow the brakes to operate properly at a much higher temperature. When pads get hot, the resins and binders that hold the friction material together with do 2 things, either melt or "gas". If they melt, this will act as a lubricant and the brakes won't work, if they gas, the gas will tend to float the pad off the surface of the rotor, so all your pedal pressure goes into compressing this gas rather than forcing the pads against the rotor. Slotted and Crossdrilled rotors allow an escape route for these things. Crossdrilled rotors are mainly beneficial for high end racing where there is a lot of concern for the reduction of unsprung weight. Aside from that and the cosmetic aspect (face it...they look good) there is no reason to go with crossdrilled rotors. Slotted rotor maintain about 95% of the friction surface that the original rotor had while crossdrilling removes much more material leaving only about 70-80% of the original friction surface. A crossdrilled rotor also does not have holes passing evenly over the entire pad as do most slotted rotors, leading to uneven pad and rotor wear because the pad is contacting the rotor for a full 360 degrees at certain points and much less than that at others. Crossdrilled rotors generally wear out pads faster than slotted rotors as well. Another problem with crossdrilled rotors is that they sometimes develop stress cracks around the holes. When the drilling takes place, stress risers are formed because the "web" of the casting is disturbed. Slotted rotors do not have this problem....especially if the slots do not extend past the outer edge of the friction surface. Slotted rotors are better for the street.....Crossdrilled for the track if you are changing rotors after every race and they are not repeatedly heat cycled, which will most likely promote cracking.
Chuckie Wilson wrote:I'm running on powerslot slot rotors and I must say, they are great.I have hawk brake pads on them and the two seem to be a great combination. Great stopping power.
