Hey guys, i thought i had my mind made about what suspension i was going to get which was the Tein Basics, but now i'm wondering if i should go for the Tokico D-Specs and Eibach Sportlines. What would you guys choose if you had a choice? Give me your opinions on both setups and what one would be easier to install?
i just put my dspecs n sportlines on and i love it. i was on dropzone coils. the ride is amazing. u will not be disapointed
Well i went with my gut and got the dspecs and sportlines thanks for the info on em jwagg. What settings do you have your d-specs on as of now? When you adjust them do you have to do anything else with the suspension like aligning or can you do it however many times you want?
Get an alignment a week or two after you install them (drive around on them for a bit). The strut's setting will not affect your alignment what-so-ever (and dont let ANYONE try to convince you otherwise! the only case this happens is with coilovers when you raise and lower the car which affects camber, but the effect is minimal).
As for setting, youre going to want to break them in for 500miles on 5 turns from full hard, then after that play with them to get them where you want them - no one can tell you what feels better to you than you
Glad you like yours jwagg
why should i get an alignments a week or two after? couldnt i just get them aligned after i get them put on?
